Question about Rockford Fosgate Punch 300S Car Audio Amplifier
No sound i have power to my amp but there is no sound. The amp is a Rockford Punch P3001
  • Bryan Epland May 11, 2010
    Hi, So to get this straight, you have power to it, RCA's hooked up, and the amp turns on when the stereo is on, correct?
    Problem Solver:
  • 5 Answers
Interchange with a known working amp, if work check your wiring and speakers.
Posted on Aug 23, 2009
6ya staff
SOURCE:
Where's the fuse located in a Fosgate p300-1 amp?
It is just to the right on the rear of the amp next to the 12 V + - RTO +
Here is a link to a picture:
http://www.crutchfield.com/S-mj0Klw5sfLm/p_575P3001/Rockford-Fosgate-Punch-P3001.html
Feb 14, 2012 | Rockford Fosgate Car Audio & Video
Is the p3001 bridageable?
The Punch P3001 is a 2 ohm stable monoblock amplifier. It therefore has only 1 channel. Not bridgeable.
Below are the specs off the rockford site.
  • Punch P3001 - 300 watt mono amplifier
    150x1 @ 4 ohms, 300x1 @ 2 ohms, 12dB/oct HP/AP/LP crossover variable 40-400Hz, RCA inputs, RCA pass thrus, cast aluminum heatsink, military spec PCB, and remote Punch Bass EQ with 0-18dB @ 45Hz. H 2.4" x W 11" x L 11.7"
  • If you are using your amplifier at a 4 ohm impedance then you will only have 150 Watt delivered to your woofer or woofers. If you are running your amplifier at a 2 Ohm load you will be recieving 300 Watt to them. This however will also draw more current to deliver this power.
    If you are certain that you can deliver the correct current to the amplifier and you are running a 4 Ohm configuartion. Then consult a Rockford delaer for a sub upgrade.
    Aug 12, 2010 | Car Audio & Video
    Hey i was wondering on the model punch 325.1 rockford amp what positive and negitive hook ups do i use for bridged channel.
    the amp is a mono block so there is no bridge mode. The 2 speaker terminals are provided for easy connectivity of multiple speakers
    Jun 05, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
    P3001 problem
    if amp is mounted to back of the box try and move to in front of box near subs or port. the air movement of the sub will help keep the amp cooled. or you can orer some 12v cooling fans and take back plate of the amp and cool it that way. or you can buy higher quality audio, your choice
    Feb 20, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
    Rockford P3001 amp not working
    peel the cover completely off the amp and give it some power- if the amp is blown there will be a tiny light lit up on the circiut board that quite simply says "SHORT"-If its blown then theres nothing you can do unless you are a badass of course- but if the amp is dear to you and you want to spend a little money on it to get it up and running again- go to rockfords website and get into the forums and ask the question-where do i get my fosgate fixed and it will pull up some mumbo jumbo but it tells you about a place called LANDIS TECHNICAL that bought up all the parts to their amps and is in the business of restoring the amplifiers to their factory specs and even sends you a new power certificate to go with your new and improved amp.hope that helps you-
    May 26, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
    My amp only powers the subwoofer when the radio is on but wont when the cd player is on
    The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
    Jun 24, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
    Punch Amp
    A Line Output Converter (LOC) is the cheapest, simplest option. You should be able to get one at any of the local car audio shops.
    Apr 29, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
    RF P3001 power problems
    check your sub woofer connection if you have multiple subs the could be wired in a parallel or with has to many ohms that my cause it to not hit right and cause the amp to get really hot and cut in and out
    Nov 15, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
    Rockford Fosgate Punch 300S Car Audio Amplifier Logo
    125 people viewed this question
    Top Rockford Fosgate Car Audio & Video Experts
    seankane89
    Level 1 Expert
    Professor_V
    Professor_V
    Robert Rankin
    Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
