Question about Sport & Outdoor - Others
Smoking outboard 1998 mercury 6 hp 2 stroke. Fuel/oil mix is 100 to 1, the engine smokes bad in all throttle ranges. Is the fuel mix wrong or are the rings bad ? thanks
Posted by westjp on
Anonymous
    Problem Solver:
  • 7 Answers
Sounds like your running a bit rich. Try leaning down your air/fuel ratio.
Posted on Aug 23, 2009
Brand new tailgator gas 63cc and has smoked and choked from out the box and this is the second day now wont stay running
assuming this is a 2 stroke small engine, smoking is a sign of wrong oil / fuel mix
add to that it the oil mix is wrong, the jets in the carby have trouble passing the fuel easily so there will be a choking problem
It is a 4 stroke , take it back for a warranty check and adjustment
Apr 16, 2018 | Garden
WHATS THE FUEL AND OIL RATIO FOR 25HR 2CYL OUTBOARD MERCURY
need the year of manufacture as some 2 stroke units have oil injection that automatically mixes the oil in the correct ratio for engine rpms otherwise it is 50:1 ( 50 parts fuel to 1 part oil)
oil requirements --certified tc-w3 2 stroke outboard oil ---not ordinary engine oil
reference
google --type in mercury outboard oil to fuel ratio
May 07, 2017 | Mercury Boating
Does this engine require mix gas?
Peter
you are too short on details like make model , 2 stroke or 4 stroke
read your user manual or look on the petrol cap as most have the ratio on the bowser emblem
so for an answer, it is most likely a 2 stroke and so-- yes-- it will require a oil/fuel mix in the tank
if you do not know it , start with a ratio of 40:1 ( 40 fuel -1 oil) and only use 2 stroke oil not normal engine oil
run at rpms and there should be a trace of blue smoke
too much smoke cut the oil back to 50:1 and no smoke increase the oil to 30:1
go google and type in user manual for ( make and model ) --and the ratio will be in that print put
Aug 19, 2016 | Garden
Where do i fill the engine oil on my 1998 gp 1200 waverunner
I looked at the manual located at: http://www.865-customz.com/manuals/98%201200%20gpr%20Owners%20Manual.pdf
According to this manual you have a two stroke engine. Two stroke oil is mixed with gasoline.
From Wikipedia:
Two-stroke oil (also referred to as two-cycle oil, 2-cycle oil, 2T oil or 2-stroke oil) is an engine oil intended for use in crankcase compression two-stroke engines.
Unlike four-cycle engines which have a closed crankcase, these lightweight engines use the crankcase as part of the induction tract, and therefore, oil must be mixed with gasoline to be distributed throughout the engine for lubrication. The resultant mix is referred to aspetroil.[1] The two-stroke oil is ultimately burned along with the fuel as a total-loss oiling system. This results in increased exhaust emissions, sometimes with blue smoke and/or a distinctive odor.
Feb 02, 2014 | 2004 Mustang Factory Wiring Diagrams
Have a 200 hp mariner which surges while running and smokes a lot when idleing
Fuel mix is likely, ensure manufactures specs are followed when mixing. Most modern 2 stroke outboard engines run on 100 to 1 mix, unlike older ones that ran on 50 or 33 to 1.
Cheers, Timo.
Apr 17, 2010 | Boating
My 81 yamaha enduro is smoking badly
Same happended to me with exactly the same motorcycle... I solved the provblem by replacing the crankshaft oil seal on the rightside of the crankcase. It solved the problem immediatly!
Jun 04, 2009 | 1974 Yamaha DT 360
Dirtbike is smoking
could be too much 2 stroke oil in your mix or worse case, your piston rings are going.
Nov 20, 2008 | 2003 Suzuki RM 250
Sport & Outdoor - Others Logo
391 people viewed this question
Top Sport & Outdoor - Others Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
