Question about Phoenix Gold XS2300 Car Audio Amplifier
Can i hook up a powered 12'sub to a Pheonix Gold xs2500 amp without blowing the speaker
Posted by swank420 on
Mark Skinner
    Novelist:
  • 79 Answers
First I hope you remove the speaker wires from the speaker that come from the built in amplifire. You cannot hook the powered sub to the amp without doing that first. Then all you need to do is run speaker wire from the sub out of the box to the amp. In no way can you hook up any other part of the powered sub, but the sub itself, to the amp. If you know the wattage of the sub and the ohms then wire it to the amp correctly. Your phoenix amp will put out 125 watts x 2 at 4 ohms and 250 watts x 2 at 2 ohms and 500 watts x 1 at 4 ohms bridged. Remember, only the sub itself in the sub enclosure can be connected to the amp. Hope this helped you. Let me know if you need more help.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Posted on Aug 23, 2009
No sound from subs
You need power to the amp. If the light on the amp is not on then your amp is the problem. Get power to it.
Nov 10, 2013 | Phoenix Gold Xenon-400.1 Car Audio...
800 watt mono block sony xplod amp blowing my dual coil 1500 watt subs
if the wiring to the sub is correct, then you have something wrong with the amp itself... something is power surging to the subs which is causing them to blow
Aug 25, 2012 | Car Audio & Video
I have 2 cerwin vega hed 12" subs , whats the most power of amp i can buy two power them both
if you can afford it, get a pheonix gold amp, cerwin vega's are hard hitters and need lots of juice. get yourself a 1500-2500 watt amp, you will be pleased
Jan 12, 2010 | Cerwin Vega HED-12 Car Subwoofer
I have 2 kicker cvr 4ohm dvc hooked to a pheonix gold rival amp
If the amp is not kicking what it should it probably s a wattage problem. Check to see if the alternator has high enough voltage distribution. That is also why it keep shuting down.
Feb 28, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Subs
I looked up that amp, it doesn't have a listing for 2ohms x1 but it has 2 ohms x 2 and its at 250watts. For this situation, I would recommend a different amp or different subs. Right now you are getting the most you can get out of your sub/amp combo, if you only have single voice coil subs. Which is common in the mtx preloaded boxes. Either you want an mono block amp stable at 2 ohms or 2 dual 4 ohm voice coil subs. If you got the subs you would wire the voice coils in series so you could get 8 ohms then the subs in parallel so you could get 4 ohms, which would be the best for that particular amp. Good luck.
-Andrew Hawkins
Aug 23, 2008 | Legend LA1490 - American Legacy Series 2 -...
Wondering why im blowing fuses
The most common reason for an amp (in good working order) to blow fuses is a speaker load that's impedance is too low. You may need to rewire your speakers.
Let me know if you have any other questions.
Aug 21, 2008 | Legend LA1490 - American Legacy Series 2 -...
Wiring my subs to my amp
bridge it and rear channel if you need to know how to bridge let me know
Feb 07, 2008 | Phoenix Gold Octane-R 15.0:1 Car Audio...
Whats is the perfect amp?
I have 2 of these 12" running in a Large slot ported box with an:
"Ultra Linear UL2402"
600RMS X 2 @ 4Ohm (Stereo) 1200RMS X 2 @ 2Ohm (Stereo) 2400RMS X 1 @ 2Ohm (Mono)
Can be run in Tri-mode with 3 8Ohm subs, which these subs are. I have not tried this mode. This is
600RMS X 2 @ 4Ohm = Max RMS of your subs. You should run the max of your subs, less wear on the amp you are using , and i doubt you will ever need to turn it up far before it blows out your trunk or window :P
1200RMS X 2 @ 2Ohm = Blown Subs!
Has 4 x 25amp fuses, most will tell you this only has an RMS of around 845, an "ultra linear circuit" produces twice the output power over Modern amps.
Can had on Ebay for around $100. I bought mine for $101.
This Amp pounds, i could quickly tell a difference going from 300RMS X 2 @ 4Ohm with a Kenwood amp. I Had to turn all my settings down on the new amp to have a better balance in sound.
Jan 29, 2008 | Volfenhag ZX-4712 Car Subwoofer
Phoenix Gold XS2300 Car Audio Amplifier Logo
264 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Tom Chichester
FastHarley
FastHarley
brian williams
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
