Question about Canon PowerShot S1 IS Digital Camera
The flash pops up, but it doesn't flash
Even when on "Auto," the flash WILL pop up when I hold the button halfway down. It won't flash, though.
Posted by Beatlesfan22 on
  • Beatlesfan22 Aug 23, 2009
    When I take the actual picture, though, it still doesn't flash.
Anonymous
    Sergeant:
  • 151 Answers
It is normal that when you press the shutter button half the flash won't fire because you're focusing on a subject upon pressing the shutter half way
It's just like you are locking a subject upon pressing the shutter half way
Posted on Aug 23, 2009
Is there any Option for solving not working Flask of Nikon L120, Many times I have looking for others opinion. Even reset to Default setting also but not working.
There is a button to release the flash and that makes it pop up. I think in a full Auto (I do not use any camera this way) if it is too dark it should pop the flash up. If you can set the MODE to 'P' you control the flash... not the camera. The Little pop up button is in front on the Left side if you were holding it to take a photo.
Internal flash won't work anymore
Try a factory reset. In the menu go to the third spanner and select 'Clear settings'
To pop up the flash put the camera in manual mode (M) and press the flash release button and it should pop up.
3helpful
2answers
How do I disable the pop-up flash on Nikon D5000? Thanks
As long as jog dial is set to M or manual, the flash will not pop up automatically. Be reminded though because you have to set everything manually. If you want the auto settings without the flash, set the jog dial to the icon that looks like a lightning with stop/ no sign
I bought my new canon eos 60D..i put on external flsah to use..then after i take off the external flash, my camera's built in flash cannot pop up to take flash even i had press the flash button. How?
Hi, What external flash did you use on your Canon 60D? The internal flash will not automatically pop up if in the "Creative Zone" it will pop up with the button in the creative zones (M, AV, TV and P) it will not pop up with the button if you are in the the full auto mode (that's the little green box mode) but, should pop up automatically if required. The flash should pop up automatically in the basic zone for Portrait, close up and night photography, the button won't activate (pop up) the flash. Also the internal flash will not pop up if there is an accessory in the hot shoe. Again what external flash was it you used and did it flash?
Canon 450D - Error 99 only when flash pops up
Flash Tube is bad inside the Flah head, tccamerarepair.com
EOS Rebel XTi 400D flash not popping up
Flash will automatically pop out only in AUTO mode, if the camera needs some additional lightning. In manual modes, you should use the flash button located at the left down side of the flash compartment, to manually force the flash to pop up
Why won't the flash on my e500 pop up when the correct button is pressed or when I try to take a picture that requires a flash?
When you take pictures in AUTO, Portrait, Macro or Night scene mode, the built-in flash will automatically pop up in low-light or backlit conditions. If you want to control the flash pop-up, set this function to OFF.
1 Menu [AUTO POP UP]
2 Use control dial to select [ON] or [OFF].
3 Press the Ok
button.
If you are in any other mode the flash will not auto pop up.
Flash not working
pop up the flash and you can select flash mode by pressing the arrow like button press right to select the flash mode....
3answers
How to switch on Auto Flash in Auto mode
Put the camera in "P" and press the flash button above the lens release. If the flash pops, than you probably just have too much light to need it when you are in auto. The flash button is not active in auto so if the xti doesn't want the flash in auto, u can't make it fire. If the flash button does not make the flash pop in "P", search this site for another post about flash not working and u will find that this could be the flash deactivation button in the hot shoe sticking. Not likely though with a new camera unless u have had a speedlite mounted alot.--
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Canon PowerShot S1 IS Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Ekse
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
