Question about Amana Dehumidifiers
I have a dehumidifier in my basement and attached a garden hose to the outlet and have it draining into the sump pump drain--however it's draining into the bucket and not through the hose. And I cannot figure out where I went wrong when I look at the manual.
Posted by aamartha on
Thomas Stewart
  • 582 Answers
WHEN I BROUGHT MINE I HAVE A HOSE RUNNING TO A FLOOR DRAIN BUT REMOVE THE HOSE SEE IF THERE IS A PLASTIC COVER INSIDE WHERE THE HOSE HOOKS ON FROM THE FACTORY THE CONDENSATE PAN IS MENT TO HOLD WATER AND THIS PLASTIC PIECE HAS TO BE REMOVED FOR HOSE USE
Posted on Aug 23, 2009
Where do i find the model number for an older model goldstar dehumidifier and where can i buy a hose to connect it directly to the sump pump?
Any garden hose will fit the drain connection on your dehumidifier. However, the hose can not be longer than 5 feet. As the drainage relies entirely on gravity to drain. Connecting it directly to a sump pump is not a good solution. Allowing the hose to drain into the sump pump's water collection tank is your only option.
Hope this helped you.
Jun 24, 2011 | Goldstar Dehumidifiers
I am thinking of buying the ADER50LP. Can a drain it directly to a floor drain, by-passing the bucket? If so, does it have an external spigot or will I need a hose? Are ADEW50LP and ADER50 LP identical?
You will need to use a drain hose that is no longer than 5 feet. Using a hose relies entirely on gravity. So, the hose must slope downward with no kinks. A short 5' section of Garden Hose works well. The female coupling end attaches to the dehumidifier. It's a very effective way, not to having to stop and drain the tank time it's full.
The ADEW50LP, is a low Temperature Unit, which designed for basement applications.
The ADER50LP, is a standard unit. Used for all applications, other than a basement.
Both have the external drain feature and the same water extraction capacity.
Hope this helped you. Please let me know.
Jun 21, 2011 | GE Ader50ln Dehumidifier
Hello, I need a dehumidifier of 50pint or more that stop when the humidity level is reach and will restart when is too high. I look for a lot of brand and model and I cannot find one thanks for your...
The fifty pint capacity might be a challenge ... think about this ... 6 + gallon tank @ 7+ pounds per gallon ... 42 pounds of water to drag from the dehumidifier to the drain? Who is going to do that?
All dehumidifiers run at some % of humidity (via Humistat), (like you are asking about) i.e. come on at some % above the setting and go off when the setting is reached. I suggest you find one that has a standard one or two gallon tank that also features a hose connection in the tank. Run the hose from the tank to the floor drain in your basement or a drain near what ever room you are trying to dry out. When you connect the hose --- you will have to put a hole into the fitting on the tank for water to flow. The idea of the tank is that the machine will run on the setting until the tank fills up ... at which time the tank full switch will not allow the machine to run again until you dump the water (and you want to drag a 6+ gallon tank, 42+ pounds, around?) . If there is a hose attached, the tank never fills up.
Some dehumidifiers feature a pump to which will pump the water to a near-by drain. You may be able to rig such a setup yourself using a small pump like a fish pond pump or similar.
You may want to consider using two dehumidifiers (with or without hoses) rather than one BIG machine. I run two machines from a major USA retailer (one in each end of the basement) and they run into the near by sump and the system works fine @ my house.Thanks for your
Thanks for your question @ FixYa.com
Jun 05, 2011 | Dehumidifiers
/my dehumidifier has a hose attachment on the back. how does that work?
The hose attachment is used in place of the water collection bucket, to drain the water directly into a floor drain or a sump pump holding tank. A garden hose is connected to the "hose attachment" and run to the floor drain or sump pump holding tank. However, it will not drain UP, only DOWN.
Hope this helped.
Mar 20, 2011 | Amana Dehumidifiers
How do I connect the hose? lost manual
If you asking about the drain hose. There's what looks like a hose hookup on the back of the unit, down near the floor. It's probably plastic and is threaded to accept a garden hose. You may have to carefully knock out the opening of the plastic connector, to allow the water to drain into the connected hose. The hose then should go to a floor drain or sump pump. Keep in mind, the water will not drain up.
Feb 08, 2011 | LG LHD65EBL Dehumidifier
50 pint dehumidifier has drain hose connected but fills up the drain bucket and stops running....
safety switch is turning off the dehumidifier....you need to drain out the bucket more often....or put the drain hose into an actual drain....ive seen some people run a small plastic hose from the dehumidifier to the sump pump hole in their basement.
Jan 27, 2010 | Frigidaire Dehumidifiers
Connecting a drain hose
Most units have a drain connection, either on the machine itself, or in the collection pail. These connections usually fit standard garden hoses.
Jul 05, 2007 | Maytag M3DH30B2A Dehumidifier
Connected Drain Hose - Is not draining, what gives?
Usually all you have to do is to remove any cap on the outlet fitting, attach the hose, & make sure it has a downhill run to the drain or well. Visual inspection should be enough to guarantee no obstructions exist.
Jun 24, 2007 | Haier HDN655E Dehumidifier
Dehumidifiers Logo
636 people viewed this question
Top Amana Dehumidifiers Experts
NOEL
NOEL
Tom Chichester
Terry
Terry
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
