Question about SanDisk Audio Players & Recorders
Cannot pair my sandisk with my bluetooth headphones there is a different headphone set previously parred in the unit
Posted by Frank Sibolski on
5 Related Answers
Fixe_You
Jalal Sordo
  • 1800 Answers
SOURCE: Pairing bluetooth headphone and mp3 player
search for devices option and visibility!! plz rate this post
Posted on Aug 25, 2008
Anonymous
  • 5 Answers
SOURCE: i-tech blueband headphones, how to parring?
The Itech manual I have says to try 0000 or 8888 or 1234 Codes to Sync it up. I did the usualy 0000 until I was blue in the face then read the Chenglish manual, 8888 worked for me. These Itechs are a bit different but VERY kewl.
Posted on May 03, 2009
Anonymous
SOURCE: Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Posted on Aug 19, 2009
Anonymous
  • 11 Answers
SOURCE: Windows 7 and Dell BH200 Bluetooth Headphones
You have to set bluetooth as default audio device. For doing this, go to >Contro Panel> Sound and Audio Devices>Audio(Tab) and in Default Device choose bluetooth device.
In my case, I had problem when i installed SP3 on XP. I changed my bluetooth driver to "Toshiba Bluetooth Stack V6.00.10" and it worked for me.
Posted on Oct 31, 2009
Chris McWethy
  • 170 Answers
SOURCE: How do I pair insignia bluetooth headphone with
The Insignia headphones must be set to "pair".
With the headphones off, press and hold the power button on the headphones until the logo starts blinking red/blue. You are now in "pair mode". Have your Touch look for bluetooth devices and it should see it now.
Hope this helps!
Posted on Apr 14, 2010
How to sync headphone to amazon echo
The first thing you'll need to do in order to pair your Bluetooth headphones is to make them discoverable. Turn on your headphones and press the Bluetooth discovery button. On AirPods, it's the small button on the back side of the case.
While your Bluetooth headphones are discoverable, say, "Alexa, pair my [Name] headphones. If everything is ready, Alexa will automatically pair with your headphones and you're ready to go.
If you're not in a situation where you can or want to talk to Alexa, you can manually pair your headphones. You're going to need to actually touch your Amazon Echo Show screen for these steps, which is nice because ... you know, it's a touchscreen.
  1. Swipe down from the top of your Echo Show screen and then tap Settings.
  2. Tap Bluetooth.
  3. Select your headphones.
Your headphones will pair with the Amazon Echo Show and audio will begin streaming to them instead of the built-in speaker.
Oct 10, 2017 | Amazon Computers & Internet
I lost pairing on headset and iPhone. Tried to pair again but headphones won't pair with my iPhone now.
Pair your device with a Bluetooth accessory
  1. On your iOS device, tap Settings > Bluetooth. Stay on this screen until you complete the steps to pair your accessory.
  2. Place your accessory in discovery mode and wait for it to appear on your iOS device. ...
  3. Tap your accessory to pair.
Set up and use third party Bluetooth accessories
Mar 09, 2016 | Yurbuds Liberty Bluetooth Headphones Black
Conecting wireless headphones LC195L9A
How Wireless Headphones Work and How to Connect Them jabra_revo_wireless_image_1440x1440px_08.jpg?h=204&w=204Wireless headphones are headphones that connect to a device, such as a smartphone, stereo speaker, television, gaming console, computer, or other electronic devices without using a wire or cable. Wireless headphones work by transmitting audio signals through either radio or IR (infrared) signals, depending on the device.
From call centers to fitness centers, wireless headphones are used by millions of people every day for work and play. For example, wireless headphones are popular with gamers, since it frees you to move around without having to worry about a cord. People doing a workout at the gym or in front of their TV in the living room love the freedom of wireless headphones. They are also perfect for people who want to watch late-night television without disturbing others.
Wireless headphones work by connecting, or pairing, with the device you want to use, through a radio or infrared signal. Many devices use Bluetooth technology to make connecting easier for the user. Devices with Bluetooth technology can connect and exchange data over very short distances using radio transmissions.
A product with Bluetooth technology has a tiny computer chip inside that contains the Bluetooth radio, and software that makes connectivity between devices possible. So when Bluetooth-enabled products, such as a cell phone and headphones, are in close proximity to each other, they connect, or pair. This enables you to talk on the phone or listen to music without wires.
Connecting a wireless headphone differs depending on the device you are using, but it's easy once you know how. Here is a list of the most popular devices that people use with wireless headphones and how to connect them.
Connect Wireless Headphones to a TV
First, make sure that your base is plugged in and the headphone batteries are fully charged. Ensure that the headphones and television are in close proximity to one another. Turn the headset on. Go into setting on your TV and turn on Bluetooth. Find the headphones under Bluetooth devices in your TV and you should be able to hear the television.
Connect Wireless Headphones to an xBox 360
The xBox 360 supports two different types of wireless headphones, ones that have Bluetooth capability and ones that do not. The first method explains wireless headphones with Bluetooth capability.
Xbox 360: Headphones with Bluetooth
  1. Plug your wireless headset into the console to install the latest headphone drivers. You will need to be connected to xBox Live in order to do this step.
  2. Make sure that your headset is charged, which can be done by simply plugging it into the unit. If you charge your headset through the console, it will connect automatically most of the time. If they don't connect automatically, turn on your console first and switch the headset so that it is in xBox mode.
  3. Press the power button for two seconds until it flashes green. You should then hear a start-up sound, and when you hear that, press the connect button for two seconds.
  4. After you release that button, press and release the connect button on the console within 20 seconds or the connection will not be made. The green lights will flash three times to let you know the connection was a success.
XBOX 360: Headphones without Bluetooth Capability
  1. Make sure that your headphones are charged, which can be done by plugging them into the USB port of the console.
  2. Turn on the console and the headphones. After they are powered up, push and release the connect button on your console.
  3. Within 20 seconds, press the connect button on your wireless headphones for two seconds. You should now hear sound from your headphones.
Connect Wireless Headphones to the iPhone
Setting up your wireless headphones with Bluetooth technology is easy on the iPhone. Here's how:
  1. Find the "Settings" icon on your iPhone, which is normally on the home screen.
  2. Open and click on the "General" button.
  3. Then, hit the "Bluetooth" button and slide it over to turn the function on.
  4. Your iPhone should find the device once this is enabled and should show the device name on screen. When it does that, you will need to hit the "Pair" button in order for the devices to sync. You may need to enter a four digit password, which is provided with your wireless device.
  5. Once that is entered, hit "Connect" on your iPhone to complete the setup. Your headphones should now be working properly.
Connect Wireless Headphones to the PS3
  1. You will first need to register the headphones to the PS3 through the Bluetooth settings. Here's how:
  2. Go to the XMB home menu and select the "Settings" icon.
  3. From there, select the "Accessory Settings" icon, and from that menu, find the option that says "Manage Bluetooth Devices."
  4. If there is no current Bluetooth device registered on the PS3, there will be an option that says "The Bluetooth device has not been registered. Do you want to register?" You will need to highlight the "Yes" option and click the "X" button on your controller. If the pairing was successful, the device will show up on the screen.
  5. Next, you will see a screen that says "To register (pair), you will need to prepare the Bluetooth device. For information on preparing the device, refer to the instructions supplied with the Bluetooth device."
  6. Click on "Start Scanning" on the screen with your "X" button so that the PS3 can start to scan. Also, you need to make sure your headphones are in pair mode so that the PS3 will recognize the device. If the pairing was successful, it will show you on the screen and you just need to hit the "X" button to continue.
  7. You will then be asked to enter the pass code or security key that was provided with your wireless device. Use the keyboard that is provided on the screen to enter the pass code. Once everything is entered properly, a message tells you that the device has been registered.
  8. Next, go back to the "Accessory Settings" menu to access the "Audio Device Settings" menu. Select the "Input Device" option by clicking "X" on the controller. When the new menu opens, look for the proper microphone input that corresponds with your device. Once you find the right one, click the "X" button.
  9. Select the "Output Device" option to select the headphones. Once you search through the options that the system recognizes, click "X" on your wireless headphones to select them. You should now be set up and ready to use the wireless headphones and microphone.
Connect Wireless Headphones to an iPod
  1. jabra_revo_wireless_image_1440x1440px_14.jpg?h=444&w=444Make sure that your wireless headphones have Bluetooth capability.
  2. Access the "Settings" icon on the home screen of your iPod. Select the "General" option once you are in that screen.
  3. You will then see an option that says "Bluetooth", which you can slide over to enable Bluetooth on the iPod.
  4. Be sure that your wireless device is in discovery mode so that the iPod can recognize it.
  5. Once you enable the Bluetooth on the iPod, it will list any devices that is recognizes. Simply click on your wireless device when the iPod shows it and click the "Connect" button. Your headphones should now be paired and working properly.
HOPE THAT HELP - GOOD LUCK.
Feb 01, 2015 | Sylvania LC195SL9 19 in. LCD TV
Pairing iphone6 to auvio bluetooth
I think what you are asking is how to connect the headphones to the iphone via Bluetooth.
switch on the headphones Bluetooth....go to general settings in iphone ... Switch on iphone Bluetooth....then choose detect devices....when it finds the headphones... Click "pair" ...it will let you know if pairing was successful.once it remembers the device you won't need to do all that again next time you want to use the headphones.now and again you will need to charge the headset up.
Jan 22, 2015 | Audio Players & Recorders
How do I pair my phone and iPod at the same time?
I don't think you can pair two devices at the same time. You will have to pair one at a time . On the phone go to connections and bluetooth , switch bluetooth on and make sure it is visible. Press scan for devices .your headphones should be shown in list if they are set to visable .press pair and a option to put in a 4 digit code willcome up type in a code and put same code in the headphones and press pair these devices. Do the same with the ipod but type in a different code and put code for ipod in headphones pair devices . You should be able to listen to either one
Jan 21, 2015 | Cell Phones
I did pair the turtle beach head set stealth 500 but when I turned off the power then turned it back on it won't pair with thePlaystation 4 system .?
what did you pair it with the first time? the ps4? if you pair it with one device and then want to pair it with different one, you need to either turn off the first one, which will make the headphone search for another signal or, there should be a bluetooth button on your earphones. this also makes it search for another bluetooth signal.
for example, i use my bose bluetooth speaker for my phone and my laptop. when it's paired with my laptop and i want to switch it to my phone, i have to turn on bluetooth on my phone, press the bluetooth button on my speaker and then it connects to my phone.
Nov 09, 2014 | Audio Players & Recorders
I have a bluetooth headphone (skech bt561) wich is paired with my previous mobile phone, my new phone is an HTC ONE and can t detect the headphone via bluetooth do you have any solutions? thank you.
  • Universal Bluetooth headset for Apple iPhone 6/5s/5c/5, iPhone 4s/4, Samsung Galaxy S5/S4/S3, PC Laptop, and other bluetooth device;
  • Deep Sleep mode extends battery life;
  • Noise-cancelling microphone reduces background noise;
Amazon com Charm sonic Bluetooth Headphones V3 0 Handsfree Stereo Wireless...
Dec 21, 2013 | Computers & Internet
How do I install wireless headphones on a Panasonic Viera TV
Your wireless headphones work with input from the audio output to the device base. Connect this unit accordingly with the power for the unit. switch on the tv and set your headphones to the desired frequency to lock on. Hope you get this right. good day
Jul 02, 2010 | Panasonic RP-HVS20 Consumer Headphones
How do I pair insignia bluetooth headphone with Ipod touch When I have my ipod search for bluetooth devices, it acts as if it does not see the headphones.
Hope this helps!
Mar 29, 2010 | Insignia Bluetooth Wireless...
70 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jean Sintulaire
Muntejaya Ginting
Muntejaya Ginting
Daniel Dollive
Daniel Dollive
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
