Question about Bose Audio Players & Recorders
I have a Bose radio/cd player model awrc-1g that will not power up. It was working fine, I went away for a weekend and upon my return noticed it had no power. I have tried other outlets. Thanks
Posted by Chip Norra on
2 Related Answers
Dennis McCollum
  • 137 Answers
SOURCE: I have a Bose Wave radio AWRC-1g. The CD player
Yes you have a defective laser assembly. The 139 is a great price as buying the laser lens alone will cost you around 70 .Bose will also upgrade with any new software and will also provide you with a 1 yr warrenty.
Posted on Apr 16, 2010
Anonymous
  • 198 Answers
SOURCE: no sound from bose wave
Your volume amplifier is either gone bad or you have a blown speaker itself.
Posted on Oct 19, 2010
Where can I buy a fuse for a Bose radio model AWRC-1G
Take out old one and take it to any electronics store that sells fuses.
Aug 28, 2017 | Bose Audio Players & Recorders
Tip
Cleaning stuck control buttons on Wave Radio/CD
Mine was made in 1999 and the push buttons have become "sticky"
over time (dust, humidity, whatever) and the CD tracks would skip.
The buttons are on top on my Model AWRC-1P (it's not a front-loading
CD model) so there is no access to do maintenance.
I called BOSE customer service (very helpful and pleasant folks) to
hear that there is no "fix" to the sticky button issue. Wipe the case
with a very damp cloth to take off surface dirt, and that's it.
I asked if I could use my CleanSafe aerosol "Dust Remover" that I
have to blast dust and lint from my computer - yes, was the tech's reply
but - - - ONLY IF IT IS "moisture-free" (which it is!) Point and shoot
the blasts of air into the buttons a couple of times and, voila!! No
more sticky functioning! Now the CD tracks move up and down
without a problem, good as new (almost, it is ten years old).
The Bose tech said that usually the CD player goes out in time. They
only can be serviced by Bose (about $125 for an overhaul) in Framingham MA - they do offer (or had offered) a trade-up exchange for $199 to a
new CD/radio but without the buttons and other features of my old
model. Call 800-637-8781 for Bose Service (M-F Eastern time).
Hope this is helpful info, it solved my sticky buttons problem!
on Apr 28, 2009 | Bose Wave Radio
Bose wave awrc-1g cd player spins but does not play.
You have done what i would have suggested, the Bose Wave unit will need to back to Bose for service, and there is a good chance they will need to replace the laser pickup assembly and cost should be considered even thoe it is top of the line.
Apr 02, 2012 | Bose Wave radio/CD remote control -...
No sound from bose wave radio/cd player Model awrc-1g? Mute is not on, and volume is up!
Oct 19, 2010 | Bose & Wave& Music System
Mar 21, 2010 | Bose & Wave& Music System
75 ohm antenna connection ''disappeared''
My antenna connector came off as well. After removing the two screw fron the back (on top), open the CD cover and remove the large screw at the front of the compartment. Now flip the unit over with the front of unit toward you. Insert a small flat screw driver between the cover and the botom on either side. There are two large tabs (either side) on the botom. pry away and up. Flip over and remove the cover. Careful of the ribbon cable inside, it is long enough to lift and flip the cover.
Nov 13, 2008 | Bose Wave Radio
I have a bose wave model awrc-1g cant set time from military time to regular
Hold the alarm setup button and at the same time hit the on/off button.
Oct 16, 2008 | Bose Wave Radio
BOSE MODEL AWRC-1P
My Bose mod AWRC-1P will not turn on. Please HELP ! !
WA4OBA
Feb 02, 2008 | Bose Wave Radio
57 people viewed this question
Top Bose Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
