Televison & Video Logo
Question about Coby Televison & Video
My coby tv dvd kitchen flip down tv screen went totally white. I still have sound but no picture problem. It's a LCD screen, under the cabnit tv.
Posted by sbirby13 on
Anonymous
    Problem Solver:
  • 18 Answers
Go die
Posted on Aug 24, 2009
Mark
  • 70 Answers
Could be ribon cable if it uses one or cable unplugged from pcb
Posted on Aug 22, 2009
Im trying to connect my coby dvd player to my samsui tv
Hi Maria,
You can hear the sound means your TV and the DVD player are working well. May be the video connecting cord ( yellow connector) between the TV and DVD player has gone bad. Please try replacing it. For testing, you can interchange it with any of the two sound connecting cords which have white and red connectors. I hope it helps.
White space above and below picture
Thirteen Retailers Recall 32" Coby Flat Screen Televisions ...
www.cpsc.gov/.../Thirteen-Re...
U.S. Consumer Product Safety CommissionDec 12, 2013 - This recall involves black Coby 32-inch flat screen televisions with model number ... AmTRAN Video Recalls to Repair 42-Inch JVC Flat Panel ...Missing: space
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the ... Just match up the sticker, and also add a space and n8lk, then search on amazon. .... LCD & LED TV Repair - No Image & BlankBlack Screen Flashlight Test ...
Coby DVD-209 Ultra Compact DVD Player Troubleshooting ...
https://www.ifixit.com/.../Coby_DVD-209_Ultra_Compact_DVD_P...
iFixitNot Compatible With Coby DVD Player; Disc Types Compatible; Problem Message Displayed On Screen. "WRONG ... Follow the repair guide to replace the fuse inside the device. ... The same goes for the white and yellow plugs and ports.Missing: space
Top 139 Complaints and Reviews about Coby Electronics
www.consumeraffairs.com > Electronics > Televisions
1helpful
I have a coby dvd 224 player connected to Emerson tv, and all I see on screen word video and no picture.
if you're using RCA video cables red white and yellow plug the yellow wire from the DVD player into the green input on the TV and then plug the two audio cables red and white into the same input red and white on the TV it's the green one that carries the video signal this is generally call the component input because it breaks down the colors into their components most DVD players do not have component outputs but if you hook the green and the yellow from the DVD player you should get a picture
My new coby 15" led 1526 tv has a white screen
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
2answers
TV no longer power's on. What problem is causing this condition?
If the TV AND the DVD player are not powering on, then it sounds like the problem is at the receptacle or power strip, where the TV and the DVD player are plugged in. Make sure the receptacle or power strip is working. Plug something else in, a lamp, a radio, anything, and see if it works. If it doesn't then the power strip is off or not working or the wall receptacle is not working.
3answers
I have digihome tv has sound but no picture and nothing on virgin
is this happened either watching a tv channel or even watching dvd movies?. and then does the display only white screen or a totally black screen?.
I have an AVOL 55' LCD tv and when I turn it on there is no picture. I put a DVD in and played it and I can hear sound but when it's the tv by itself there is no picture or sound at all. Ple
tried to look at the darkened room if their is a white screen, it could be the t-con board. if totally black screen, it could be the inverter board was busted or the screen back light itself.
1helpful
I bought at Toshiba HD TV/DVD combo 26" in January and last night the picture went totally white and makes a loud, fast ticking noise. Is it toast?
White screen means that the T-CON is nothing getting the 12vdc from the logic main board or the fuse on the T-CON board has blown. But first place to check will always be the power supply module first. Not sure about the clicking sound, DVD section?
Service manual: http://elektrotanya.com/?q=showresult&megnev=Toshiba&megnev2=%2026LV610U%20&kategoria=&kat2=all
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
2helpful
No Picture on 5 month old tv.
If the screen is just showing white screen, no text, no picture, then the problem cam be in the LCD controller board. I would get this fixed under warranty ASAP, nothing should have gone wrong yet. You may have a lemon, this is not a no name set.
Top Coby Televison & Video Experts
Marvin
Marvin
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
