Question about Refrigerators
Dometic rm2652 frige just stopped working, gas nor
Dometic rm2652 fridge just stopped working, gas nor electrical will cool
Posted by kccbe on
Anonymous
  • 4 Answers
Check 12V supply and fuses on lower board. If display functions okay, then look for yellow residue on back of refrigerator near burner. If yes, then cooling unit has leaked and needs to be replaced. See if recall kit has been installed, and check for 12V at both sides of limit switch. If no power on either side, then thermal link has blown, and need to be replaced, If 12V on one side, but not the other, than limit is tripped, and needs to be reset, by pushing button, or if not resetting, then replace, Check for obstructions to the bottom and top vent to make sure they are not blocked, On models with top side vent, check cooling fan for proper operation.
Posted on Aug 23, 2009
Dometic RM2652 was working fine then stopped - no lights at the control panel above the doors.
Usually there is a short in the system when fuse is blown. Check the cord as sometimes mouse can damage the cord. It is a posibility.
Check power to the electronic board.
Jan 28, 2015 | Dometic RM2652 Refrigerator
My Dometic RM2652 fridge suddenly quit cooling. No amonia smell, no yellow residue around cooling unit. Gas ignites, lites work.
what is the yellow residue around heating element? my fridge just isnt working right and sometimes stops all together, the freezer worked until lastnight but fridge hasnt cooled right for a week or so.
Aug 03, 2012 | Dometic RM2652 Refrigerator
Hello, my dometic camper fridge runs great on gas but just clicks when i switch it to electric...??? any advice thanks Stephanie
The mains heater has a different thermostat. Check power to the heater, and the back coil is getting warm
Apr 27, 2012 | Dometic RM2652 Refrigerator
I Have a Dometic RM2652 it heats up in the back, but, neither the fridge or freeze will cool down.. I've checked the fuses, tried gas and electric.
First thing I would do is check this dometic site for recall information. Have model and serial number ready.
http://67.238.126.140/recall.php
Jun 15, 2011 | Dometic RM2652 Refrigerator
My dometic refrigerator unit is not cooling properly on gas or electric. The freezer gets cool but the fridge stays warm. What could cause this?
my domestic refrg will not work on electric but will lite on gas. freezer will get cold on gas but bottom will not cool.you can plug refrg in and it will kick the gas off. you unplug refrg on gas will lite.that part of the power board seems to be working.
Apr 17, 2011 | Dometic RM2652 Refrigerator
My 3-way Dometic fridge works on gas but stopped working on 240V! ....Why?
With the 240V element diconnected, test it with an ohm meter to find it was open circuit. No heat! The 12v element still had resistance.
At the moment gas is still keeping my cool while I wait for a new element to arrive. ..... cheers
Sep 01, 2009 | Dometic RM2652 Refrigerator
Start my fridge on gas
have you ever used it on gas normally theese frige have a glow coil to ignited the pilot is it a fridge in a trailer or in a house also the themocople may me defective not generating electricity i woul need more info thanks from gilles
Mar 15, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
388 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
