Hello, I work with Osceola County, FL Habitat for Humanity.We have a dnated Minolta, Model: AFR-12, SN: 61022514, copy machine that needs servicing. When we copy the paper comes out with black. Can we fix this in house or do we need to have it services.
Sir the AFR-12 is the document feeder desiignation, the machine model number is located on the back of the machine or the right hand side of the machine (You saw the AFR-12 when you raised the document feeder correct?) As for copies being black the drum/cleaning blade mite need replacing. Remove the orginal glass the big sheet of glass and clean the optics use no liquids just a clean paper towel, there are about four minors two the right side plus clean the expose lamp (Bright lite that lites up) to copy the orginal be gentill. remove the black cover on the right hand side two mirrors under there The model mite be a EP2010, 2030, 2080, and or 3000?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Model AFR-12 is the model number of the document feeder. Need more info, possible the exposure lamp is out.
