I've got the same fridge with the same problem (believe it or not it was manufactured in 1992 so it's a wonder it's still working).
I also have been able to narrow the problem down to a defrost issue. It appears as the coils are defrosted, the leaking water drains down through the inside of the fridge, pools in the bottom of the fridge (under the bottom drawers), then when that area is full it runs out onto the floor.
I'm still troubleshooting and will post back here within a week with my results.
Okay, I can't take credit for this, but it appears the fix is to remove the rear panel inside the freezer (and icemaker too) and defrost/clear the drain tube/line that is supposed to drain the water down to an evaporator pan on the lower rear of the fridge. Likely since these units are so old they are clogged with dirt/debris. Hot water and a turkey baster will be helpful. Once the line is clear, the water should no longer drain inside the refrigerator.
