Just noticed that it is not making ice the bin that holds the ice is almost empty must how stopped sometime yesterday, it is a conquest in the door ice
Could you have inadvertently cut the IM off? Maybe it stopped working earlier and it wasn’t noticed until all ice was emptied out. In any case some testing will have to be done to determine what is bad; the ice maker or the water valve.
When the ice bin fills up, it won't let the arm all the way down. The arm must go down for more ice to drop into bin. Sometimes an ice cube or two will get caught under the arm and prevent it from cycling. Continuing to use the ice maker will empty bin but no new ice is made. Clear any ice cubes from under the arm and the cycle will start again. My ice maker takes about twelve hours to fill after it has been emptied but ice from the door is available almost imediately.
The two most common things that happen: the ice piles up too high, which pushes up the bar that tells it the bin is full and stop making ice. OR the ice sticks to the ice cube maker. If the ice pile is too high, knock it down or empty the bin. If the ice is sticking to the cube maker, try melting it and then spraying it with a non stick spray. Sometimes the water supply line is clogged, but that is not usually the problem.
is there water in the ice trays?if not try pushing the test button normally underneath the unit. possibly it will initiate a reset and start working. sometimes a limit is not activated when it should be.
