How to solve fan errors problem ?????
pls suggest me?
If you are getting a fan error, it means that your fan may be clogged with dust. Get a can of compressed air and blow out the fan. If the fan is not functioning, IE: spinning correctly, it is bad and needs to be replaced. If it is not replaced , your unit can and will overheat, causing damage to the system.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Testimonial: "Thanks"
You get a fan error? That means the heatsink fan isn't working you will probably have to call lenovol (They replaced ibm).
Testimonial: "thanks"
Open the phan with your srewdriver if u can't do it give it to a technician like myselt for him to open it and try to blow out the dust particle that mail be inside the span that done it reduce the friction and every think will be okay if not check the cable that connect the span to the motheroard
