Question about Sharp R-1850A Convection/Microwave Oven
Replacing a damper motor - Sharp R967 MICROWAVE AND CONVENTION
Should the damper door be closed when off and when the microwave is on and open when the convention is on?
I am not sure as the orientation of the new motor was slightly out and I needed to turn it to fit. Thus not sure whatis right and wrong.
Posted by am_boyd on
  • HotCap Jan 27, 2015
    I bought a Sharp Microwave Oven with Sensor, Grill and Convention functions, R-967(SL)M, a few years ago in London, United Kingdom. Problem: Now, each time the timer counts down to 1 second (for example, 1 sec. or 2 mins. 1 sec. or XX mins 1 sec.), the heating function just stop as long as the timer shows 1 second. In addition, I relocated to Hong Kong and the local Sharp customer service refused to provide any repair service (even if paying!) since I did not buy the product model in Hong Kong! The warranty period has ended, hence there is not an issue with warranty service. Appreciate if any expert(s) out there could kindly provide assistance or at least offer a direction/suggestion which I could pursue to get the appliance back to working again. Thank you!
David Hanks
    Scholar:
  • 178 Answers
The damper should closed when in convection mode and open when in the microwave mode, to keep the heated air inside the cavity.
Posted on Sep 13, 2009
Microwave oven stops after 59 seconds
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp-made models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
If a switch is all you need, we offer a universal type for only $7.50 postpaid which you can order here.
Oct 06, 2011 | Sharp R-1870 Convection/Microwave Oven
What is the cu ft, wattage, size, conventional oven yes or no, all the specs ect of the Kenmore mircorwave model #721.80833500
From the factory manual here:
SPECIFICATIONS
Rated Power Consumption ..............1700W maximum (Microwave oven+Cook top lamps+Ventilation fan)
Microwave Output ...........1100W (IEC60705)
Frequency ....2,450 MHz ±50 MHz
Power Supply .................120 VAC, 60 Hz
Rated Current ................14.5 Amp. (Microwave oven+Cook top lamps+Ventilation fan)
Magnetron Cooling .........Forced Air Cooling
Rectification .Rectification Voltage Double Half-Wave
Door Sealing ..................Choke System
Safety Devices ...............Magnetron Thermostat: Open at 145 °C ±5 °C
Close at 60 °C ±5 °C .....................Oven Thermostat: Open at 110 °C ±5 °C
Close at 0 °C ±5 °C ......................Fuse(20A)
Magnetron ......................2M282J (Toshiba)
Cook top Lamp ...............130 V, 35 W (Halogen)
Cavity Lamp ...................130 V, 35 W (Halogen)
Timer ..............................Digital,up to 99 min.(in each cooking stage)
Tray ..............Tempered Safety Glass
Overall Dimensions ........2915/16"(W)x167/16"(H)x153/8"(D)
Oven Cavity Size ...........231/2"(W)x10"(H)x141/2"(D)
Effective Capacity of Oven Cavity ....2.0 Cu.ft.
Accessories ..Owner 's Manual &Cooking Guide, Installation Manual,
Exhaust Adapter, Exhaust Damper, Mounting Kit and Filter,
Rotating Ring Assembly, Glass Tray, Metal Rack, Guide Tray.
Jul 09, 2011 | Kenmore 80809 Microwave Oven
My Sharp R-975 Microwave after settin the timer and starting only runs for 59 seconds and stops, I can press start again and it goes for another 59 seconds
Sharp models stop after 59 seconds.
I'm not sure this is a US model or if parts are still available, so look up Sharp in your country.
Mar 13, 2011 | Sharp Microwave Ovens
Sharp convection microwave R-1870 runs about one minute and shuts off. damper Motor switch?
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Dec 17, 2010 | Sharp R-1870 Convection/Microwave Oven
The microwave will run for a minute and then shut off
Sharp (and Sharp-made Dacor and Wolf) models stop after 59 seconds.
See: http://www.fixya.com/uploads/Howto/B27054B.jpg
Nov 29, 2010 | Dacor DMT2420SS Microwave Oven
The microwave will only work for 59 seconds then it stops. It is working but only for 59 seconds. I am not sure about the convection oven was afraid to try it. The unit is in our fifth wheel RV. I can heat...
We have the applicable service manuals for these models and have uploaded them to our site here and here to help you.
Apr 18, 2010 | Sharp R-1870 Convection/Microwave Oven
R-1874 shuts down after 59 seconds
That switch is supposed to tell the computer if the damper door is open or closed. If it does not go to zero ohms, the CPU doesn't know what to do. Check the thermistor too...... just in case...
Sep 12, 2009 | Sharp R-1874 Convection/Microwave Oven
Sharp r96st stops at 1 sec and halts whilst preheating oven
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
Jan 29, 2009 | Sharp R-1480 Microwave Oven
Sharp R1870
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper closes and opens depending on cooking mode. See the attached sample photo.
The damper is a door located on the right side of the innards. The damper closes and opens depending on cooking mode. See the attached sample photo.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from that Sears link or from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 27, 2007 | Sharp R-1871 Convection Microwave Oven
Sharp R-1850A Convection/Microwave Oven Logo
927 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ekse
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
