Question about Hitachi Televison & Video
I have a 55 in hitachi projection tv model #57F710G and it turns on after I unplug the power for about 30 minutes, but it only stays on for about 10 minutes at a time. Is this something I could fix?
Check power settings see if set to go off if not bad transformer board
Posted by Jerry White on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: MY Hitachi 50v500 is shutdown itself
possibly a bad power supply board.
Posted on Oct 26, 2007
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: hitachi 52 projection tv
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Posted on Dec 05, 2007
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: Hitachi 50 Inch rear projection
that could be many different things such as a defective CRT, A capacitor that has shorted. or the flyback. Unless your good at electronic repairs it may be best to call in a repair tech for that type of issue as I have only just lightly touched on the possible causes.. It will need to have the standby and operating voltages tested to pinpoint the problem if it isnt noticeable by visually inspecting for blown components such as capacitors
Posted on Jun 26, 2008
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: cleaning tv screen of hitachi rear projection tv
http://serviceman.site88.net/index.htm
Posted on Jul 07, 2008
Anonymous
  • 200 Answers
SOURCE: power light flashes on Hitachi TV model #53UWX10BA
Hi
Can u tell me model no and company name so that i can help u clearly..
If u have warranty then u can claim it..
thank you
Posted on Oct 12, 2008
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
My hitachi tv keep turning off after 5 minuted of
I just got done putting my panasonic 50 projection back together. There is a thermal cut off relay on top of your bulb box, can normally be seen after removing the back of the tv. With the tv unplugged make sure the area around this relay is clean of dust. If the simple fix dosn't work make sure your cooling fan is coming on with the tv.
Kevin
Oct 29, 2009 | Hitachi 55FX20B 55" Rear Projection...
My Hitachi 50SBX70B wont stay on
i think you may have a bad flyback. i have an hitachi that did that and ha to change mine out.
Dec 28, 2008 | Toshiba 55H70 55" Rear Projection...
No picture
Good Day;
Try resetting the TV by unplugging from the wall A/C outlet for 3 to 5 minutes, plug back in. No fix? Your TV's LAMP needs to be replaced. Part number; UX21516, for Model 55VG825.
Good Luck, big IRISH.
Jul 06, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Power up Problem
my hitachi model number:55fx48b suddenly just stopped. I can unplug the tv, then turn it back on and red led light will come on for 2 seconds and shuts back off! Can you please help me
Jun 28, 2008 | Hitachi 55FX48B 55" Rear Projection...
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Tv randomly shuts off
Replace power relays on power board...
Bill
Oct 08, 2007 | Philips 55PP9401 55" Rear Projection...
Televison & Video Logo
44 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
