For being able to use internet on your LG U880, you will need to contact the network service provider that you are using. Contact the Customer Care of the respective network provider and ask for gprs setting for the phone. They will send you some settings through sms which you will need to save on the phone. After saving the settings. Switch off your phone, remove the battery, re-insert it and switch it on. You will now be able to use internet on your phone.
Good luck and have a nice day.
A 4-thumb rating gives us motivation to answer more free question.
Well if you are tied to a particular network all you have to do is to unlock your phone to use it any other GSM network. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
There are the settings. They are the same for MMS as for WAP. I hope this helps and I have given you some help below on setting this up for O2. Thanks.
APN wap.02.co.uk USER o2wap PASSWORD password HOMEPAGE http://wap.02.co.uk PROXY 193.113.200.195 PORT 9201
1- Main Menu click on Entertainment then click on Services 2- Click on Data Account-> click on GPRS 3- Choose any account-> click on Edit 4- 1- Account Name O2 2- APN wap.02.co.uk 3- User Name o2wap 4- password password 5- Auth. Type Normal CLICK ON DONE AND SAVE IT CLICK ON BACK TWICE IT WILL TAKE YOU BACK TO SERVICES CLICK DONE AND SAVE IT->CLICK ACTIVATE PROFILE AND SAVE
NO yo have to go to settings and click phone settings then click reset settings and click MASTER SETTINGS and wait while it resets everything and then send a picture to somebody and wait if it works thats what i did to mine and now it WORKS yay.
Normally you'll need Vodafone to send you both the MMS and Internet connection settings. Then once received an save take your battery out of the handset without switching it off, remove your SIM for 10 seconds. Put it back together and send yourself a MMS and you should now be fully set up.
Alternatively here are Vodafone's settings:
Access Point
Name: wap.vodafone.co.uk Username: wap Password: wap Authentication: Normal Data bearer: GPRS Gateway IP (proxy) address: 212.183.137.12 Session mode: Permanent Port number: 9201 MMS Message (Relay) Server URL: http://mms.vodafone.co.uk/servlets/mms/
UK WAP gateway settings The following table shows basic WAP gateway setup information for the main UK mobile phone operators. The menu options differ between handset manufacturers. Some of the common menu fields explained:Bearer type: There are two types: GSM or GPRS. GSM works by dialling a dedicated WAP dial-up number and should work on any WAP-enabled handset. GPRS is a newer technology, and only works on selected handsets. GPRS is an always-on service that is billed per-kilobyte, and not as GSM, which is billed per-minute.Dial-up number - The telephone number that your WAP browser needs to dial to connect. (Not required for GPRS)
GPRS APN - If connecting over GPRS (as opposed to dial-up), you need an Access Point Node address, so the network knows where to direct your request. See our GPRS for full UK GPRS settings
Username and password - Note that these are case sensitive, and should be typed in as shown
Gateway IP details - WAP works by routing traffic through a Gateway that handles optimising the content efficiently. The address is made up of a series numbers separated by dots. This may also be referred to as the WAP Proxy Server address.
Homepage - This is the main page provided by a network operator... The front-door for access to content provided via your network operator
try this menu then settings then connectivity then network then access point then new access point then fill in it is case sensitive so do it exact name: MEdia Net bearer setting: gprs APN: wap.cingular user id: [email protected] Password: CINGULAR1 Primary server: 066.209.011.061 Secondary 000.000.000.000 then save it
then go back to menu then internet then settings then network profiles then new profile then fill in name: MEdia Net homepage: device.home proxy: on ip address: 066.209.011.061 port number: 9201 access point MEdia Net then save then options then activate
then menu then messaging then settings then multimedia then network profiles name:MMS homepage mmsc.cingular.com proxy: on ip address:066.209.011.061 port number: 9201 access point MEdia Net then save then activate you may have to highlight mms to activate .
This worked for me. Good Luck!!!
