SOURCE: How do I pause while recording?
As far as I can tell, and yes the documentation is skimpy, when you press the 'record/play' button the video recording pauses. Make sure you press the video icon button, not the 'record/play' button to get it started again. If you press the 'record/play' button, it goes into a 'play back' mode.
Hope this helps...
SOURCE: Dvr not working. Won't record, pause rewind
Try unplugging the unit from the electrical outlet for about five minutes- much longer than required- and try it again. If this fails you will need a service technician to resolve the issue. Thanks for using Fix Ya.
SOURCE: RP5010 Handheld Digital Voice Recorder: need a manual for 5010 digital recorder...
You can download the complete instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
SOURCE: I have a Fostex DMT-8vl 8 track digital recorder.
You can copy. You cannot just dump the file data. Unless you have an audio interface with multiple inputs, you can only copy 2 tracks at a time. Also, to sync the timing you'll need a midi port on the computer. Then you make the computer the "master" and the Fostex a "slave" device.
SOURCE: I have CENIX Power Voice
It is not compatible with Windows 7. You can go to the Microsoft Download Center and download and install Virtual PC. It is a console that allows you to run another operating system virtually. One installed you can install Windows XP inside it. From there you can install your application and run it from there.
http://www.microsoft.com/downloads/en/ResultsForProduct.aspx?productID=82b14654-ef9b-4403-8d0e-46cf4d29d255&stype=n_a2z
To start voice recording, follow these steps:
1. Press the Menu button to return to Main Menu.
2. Select Voice
3. Press Play/Pause to start recording.
4. To pause recording, press Play/Pause again
5. To stop recording, press Select. A pop-up window will appear on the screen. Select Yes to
save recording. The recording will be saved in the RECORD/VOICE folder.
6. Press 'button to return to the Voice Menu.
2. Select Voice
6. Press '<< button to return to the Voice Menu.
Please leace feedback
Cheers
Andy
Restoring RCA M4304A Recorder Firmware
Symtom: recorder shows OPAL splash screen, then shows "profiling requires20mb of free space, shutting down" and then shuts down. Recorder cannot be accessed by windows or the RCA easyrip software.
Solution: Use the firmware update found here: http://www.voxxsupport.com/images/downloads/OPAL_066F_85A4_85A5_0_1140_SIG.EXE
This update needs to be ran on an xp computer running 32 bitOS. It was tested in a Win 7 64bitmachine and proven to not work.
Necessary steps taken to get the firmware to properlyrestore were as follows:
1. Hold in the power (menu) button for 10 seconds(the splash screen will show and it will give the error message, ignore it)
2. While still holding the power button, press theplay/pause button and hold down.
3. Release the power button while still holdingdown the play/pause button and wait 5 seconds.
4. While still holding the play/pause button plugin the usb cable to the recorder. Continue to hold the play/pause button foranother 5 seconds after plugging the cable in.
5. Release the play pause button then launch theEXE for the firmware update. Minimize the instruction screen so you can see thefull update screen.
6. Leave the format checkbox checked (check it ifit isn't checked) formatting is crucial to this working.
7. Once the status in the update window changesfrom initializing to ready click start to update the recorder. It will go through formatting, then updating.
8. Once the status shows complete disconnect therecorder and with any luck the recorder is usable again. The media files will obviously have to bereloaded, but the recording is functional at least.
