Question about Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo Head CD Player
Cant get the speakers balance its all on the right side.
Cant seem to fegger out how to change the balance.i can change everything else. it go back and forth from
fad to right but not changing the level on the speackers.
Posted by c_russell17 on
Anonymous
    Problem Solver:
  • 9 Answers
Ok maybe i am not understanding what you are trying to do .if you are looking for balance you found it balance is front to back and side to side. if you are saying the volume wont change you might have one rear hooked up to the front and one to the back. this is most common on cars thatare hard wired "no harness"double check the way you ran the wires good luck
Posted on Aug 22, 2009
My ASUS K50IJ sound comes from only one speaker. I've tryed everything and the balance seems ok
One of the speakers failed or it has a bad connection.Most likely the non working speaker will need to be replaced.
Mar 29, 2013 | ASUS K50IJ-C1 Notebook
The sound only comes from the right side on my acer tablet
See if there's a balance control. If the slider is all the way to the right, that could explain the problem. Otherwise, since this happens with two sets of speakers, the problem is either a bad receptacle, or sound card, or, the connection between them.
I found this Windows 7 site on how to adjust the balance.. it seems to be legit: no complaints from Avast! A/V
http://www.windows7hacker.com/index.php/2010/02/how-to-adjust-audio-balance-in-windows-7/
Aug 05, 2012 | Acer Iconia Tab A50010S32u Notebook
Yamaha rx 530 center channel cuts out
Thanks for all the suggestions guys.
I've tried using the balance for left and right speakers, and when the receiver is acting up with the right speaker having a low volume, I tried moving the balance all the way over to the right speaker. The right speaker volume will not increase in volume but the left speaker will decrease in volume.
Just to clarify, the center and the rear speakers are balanced. The issue only happens sometimes when I first power on the receiver I will have no center channel. If I leave everything alone for a few mins, the center channel will come on.
So it seems to me that something one the receiver is going. The question is, can anyone suggest a physical repair for the receiver for these symptoms?
Thanks
Jul 20, 2012 | Yamaha RX-V530 Receiver
I have a Pioneer VSX 452 receiver. I am trying to run a second set of speakers off the b channel and use the a and b switches on the front of the receiver. If only the a channel is depressed the two...
Thanks for the detailed explanation...
It seems to be there is a short or misplaced (+) (-) leads on the speaker connection you made..sometimes a tiny cable piece can make a short in between the leads and cause such problem..My recommendation is:
** take all the wires off..
** install only B speaker leads and test it..( make sure LEFT and RIGHT (+) and (-) leads properly
and individually connected to the right places on the back......it is important...This causes balancing problem..
** if it works fine...
** than go ahead and install the A speaker leads..and test it..
if you do everything properly both A and B speakers should work fine as independently ...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 22, 2011 | Pioneer VSX-454 Receiver
Radio works. volume problems on drivers side front speaker
It sounds like the problem is with the speaker, not with the radio
Dec 04, 2009 | Cell Phones
No sound out of left side speakers, front and back.
easiest way to see if the left outputs have gone is to swap the right and left speakers over. if the left works out of the right channels you know if the set has had it.hope this helps
Apr 22, 2009 | 2004 Nissan Sentra
Back rear speaker wont play when singled out. more details inside
I would suggest you mdisconnect the rear speakers from the amp, take a 9volt battery and click te speakers on at a time. If proble duplicated, the you have the left speaker tied to the right somewhere.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Clarion EQS746 Equalizer - 7-Band In-Dash...
My l/r channel will not work
With the radio on u will need to push audio button it will change to something different on the face push until speaker balance comes up & then push butons below it left or right to balance each side of speakers. For me it was the left speakers that i needed to balance good luck John
Jun 06, 2008 | Pioneer DEH-1600 CD Player
Speaker volume on one side extremely low
i have the same speakers.
but isntead of one side going,
both sides are dead.
and the light on the control side doesnt even turn on
it is plugged in
but i do not know what is wrong
solutions please?
[email protected]
Jan 24, 2008 | Dell A425 Computer Speakers
Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo Head CD Player Logo
Top Pioneer Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
