I was watching the tv when it just went black and turned it self off and now the red light where it says lamp is lit. please expalin what I need to do to fix this problem.
I appreciate the information. I just need to know where I can go to get a lamp? How do I know what lamp that I need?I appreciate the information. I just need to know where I can go to get a lamp? How do I know what lamp that I need?
You can't post conmments that contain an email address.
The device sources and the inputs have not been set to the correct mod.There could be a problem with the TV it's self for it to be turning off like a problem with the power supply for the TV.
Hi, Is is standby light blinking red or any other light? Let me know how many times red standby light blinking after three seconds long pause to provide you helpful info. It seems pop sound was due to broken lamp, please check lamp inside tv and if it is broken, replace it to solve tv problem. Hope this will help. Thanks.
It sounds Lamp got broken inside, please take out lamp from TV and check its glass tube. If found broken, replace it. Lamp replacement procedure is written in user manual page-95, click HERE to download user manual copy if required. Lamp is available in Part Store. Thanks.
The POWER/STANDBY (red) indicator flashes three times If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing) A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing) A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
