SOURCE: fujitsu siemens stylistic M532 tablet not charging battery
I have just had same problem. Battery on M532 absolutely refused to charge from flat.Tablet worked when plugged in so I downloaded an app killer from android market and killed all but the essential apps then tried again and it seemed top work! Maybe background apps draining battery at faster rate than could be charged?
SOURCE: Both Charger Ports Wont Take Charges
i can suggest you get a Duracell wireless charger which you just place your tablet on and it charges?
cant connect to google i got a gmail still wont let me connect my wifi works on it thats the only place i cant go
SOURCE: rca tablet model rct6272w23 screen pixalted white then went black now wont turn on
I would recommend calling RCA support at (800) 252- 6123 so they can suggest some troubleshooting steps you can take. If it is still under warranty and you're unable to get it working then you can send it back and get a replacement
SOURCE: My RCA tablet wont charge. I have used 4 different charge cords.
the volts may notbe the same for the chrg you have... goto bestbuy just so youcan get the right style for that model plus try can check to see if it is changing
