Question about Nakamichi Televison & Video
Nakamichi smart tv showing andiord only not opening
Posted by Fgfhb on
1 Related Answer
Larry
  • 2833 Answers
SOURCE: NAKAMICHI NS4700LE 3D SMART TV How can I get firmware of my TV? Having some software issues.. please help.
Below is a link to issues with this make TV on firmware not updating...I think that will help with your issue
https://www.helpdesk.nakamichi-usa.com/firmware-cannot-upgrade
Posted on Feb 09, 2018
Nakamichi soundwave 7.1 will not sync with my LG smart tv
Assuming Reset your blue tooth on TV and unplug your blue tooth bar powered off for ten minutes then retry
Why a hard disk doesn't read in Nakamichi TV? How to fix this and why shows NO USB DEVICE, even device has been connected?
look at what cd it is written on if TV is not compatible you can use a read/ write rom to copy it to a disk that is compatible.
1helpful
2answers
How do I open the cd drawer to remove a fallen paper clip
If you do a google search for "Nakamichi SoundSpace 9 service manual" you will see a PDF file that shows how to dismantle the unit so you can get the item out.
Latest Firmware for Nakamichi Smart TV
Hi Asad
Why would fixya keep firmware for a Nakamichi TV
Nakamichi web sit would be your best bet!
If they don't have it.........
1helpful
How do you connect a Nakamichi surround sound system to my Phillips tv model 42PF7220A/37
I'm confused. The message header shows a problem with a Yamaha RX-V995 receiver.
As for connecting a Nakamichi (or any surround system) to a TV - the only connection would be the Monitor output (video connection) to an appropriate video input of your TV.
If it is a Nakamichi, it is a little older and probly predates the invention of HDMI cables. My guess is you will either use the S video output or Composite video output to the TV's input with similar connections.
This allows you to route whatever video sources you have connected to the Nakamichi to the TV.
Nakamichi tv
My smart tv nakamichi, while swith on only shows android and busy, even remote not functioning. . Pls advice
Televison & Video Logo
Top Nakamichi Televison & Video Experts
ray gallant
Tom Chichester
Are you a Nakamichi Televison and Video Expert? Answer questions, earn points and help others
