Samsung SGH-U600 Logo
Posted on Aug 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connecting my phone to my PC
When I plug my Gravity sgh-t459 into computer and open the version of samsung pc studio 3 that i downloaded from the samsung website for this phone, it doesnt connect, it just says at the bottom not connected. How do I connect start the networking wizard?
Anonymous
Level 3:
President:
  • Master 1,884 Answers
  • Posted on Aug 22, 2009
Anonymous
Master
Level 3:
President:
Answers
1884
Questions
Helped
476283
Points
5973
Nettworking wizard will be opened after you are able to connect the phone. For that you must start PC Studio and select Connect. There you will fine various means to connect. Select USB and connect. Or BT connect. Then select a comm port one by one and try to connect. One of the comm ports will accept the phone and connec.
Unlock my SGH-T459 SAMSUNG FOR FREE
You can't get any Free Code if your Mobile is locked by any Service Providers. If it is Locked so, Unlock your Samsung SGH-T459 Gravity Phone by Clicking this site http://www.onlinegsmunlock.com/. Follow the Instructions:-
1 - Switch ON your Samsung SGH-T459 Gravity without any SIM Card.
2 - Compose : #7465625*638*CODE#
How to unlock samsung gravity sgh-t459
There are lot ways To Unlock the Phone ,but Unlock code is easy and Correct way to Unlock the Phone from Network Lock,You need to specify the Current Network Lock and Country and get the Unlock code at here Onlinegsmunlock.com
and Unlock it,then You can use it any GSM Network ...You can follow the instructions below and Unlock it step by step..
Samsung SGH-T459 Gravity Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Samsung SGH-T459 Gravity mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-T459 Gravity mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung SGH-T459 Gravity with a NOT ACCEPTED SIM Card.
2 - Samsung SGH-T459 Gravity will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-T459 Gravity shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-T459 Gravity.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-T459 Gravity is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-T459 Gravity.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung SGH-T459 Gravity.
1helpful
My samsumg gravity t won't send picture messages
Your phone is capable of MMS.
Contact your cellular service provider and make sure that MMS (Picture Messaging) has been enabled on your account. If you don't have MMS on your account, you'll have to subscribe to the service or picture messaging will not work on your phone.
Also, if you don't have Samsung PC Studio 3 on your PC for your phone, here is the download link:
(Look for the word 'Software' and click on it - then click on the EXE at the end (to the right hand side) of the box.)
http://www.samsung.com/us/support/downloads/SGH-T459BGATMB#tab3
I need an owners manuel for samsung gravity 3 cell phone
You can download and print the instruction manual in PDF format from this link
Please note: Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
How do i unlock my samsung gravity sgh-t459 for free
1. Turn on your Samsung Gravity without the SIM card inside.
2. Now type in #7465625*638*UNLOCK_CODE#
Where UNLOCK_CODE represents your 8 digit unlock code. (Warning: Entering more then 3 incorrect unlock codes, may permanently lock your phone!)
3. If everything worked, your phone will say “Network Lock Deactivated
You can get unlock code from your service provider. Hope this helps
5helpful
From where I get samsung sgh-t459 usb driver software
They do not make one for your phone, and they do not have you phone setup to work with the samsung pc studio.
So the only thing you can do is this, and maybe pictures.
  1. Insert a microSD memory card into the memory card slot located on the left side
  2. From standby press the Menu key
  3. Select Settings (9)
  4. Select Phone Settings (3)
  5. Select USB Mode (5)
  6. Highlight Mass Storage and press the Save key
  7. Plug one end of the data cable into the handset's power/data port located on the right side and the other end into a USB port on the PC
  8. On the PC, open My Computer and double-click on Removable Disk (Hint: it will be assigned a drive letter and, depending on system configuration, may not be the only Removable Disk present)
  9. Using Windows Explorer, copy and paste (or drag and drop) MP3 files from your PC to the Music folder seen under Removable Disk
4helpful
3answers
A cannot connect my samsung sell phone M330 with PC. I already installed Samsung PC studio 3 and usb driver, but PC studio is not connecting with phone.
According to Samsung, neither the m330 nor any CDMA phone works with PC Studio:
"Samsung does not offer a Data Kit software package for the purpose of transferring data between the handset and a personal computer or for using a Sprint handset as a modem for a personal computer." Unfortunately, PC Studio is not compatible with any CDMA handset." So we're out of luck, unless someone has a hack. Anyone?
2helpful
What software do i need to transfer files from windows vista to a samsung gravity
YOu need samsung PC suite and device install to tranfer files to your device from vista,,,
You can download from the following link
http://www.samsung.com/us/consumer/mobile/mobile-phones/t-mobile-phones/SGH-T459BGATMB/index.idx?pagetype=prd_detail&tab=support
Please, rate this solution
Rnj VINODKUMAR
Samsung Gravity SGH-T459 Studio 3 Connection Problem
I have samsung pc studio 3, if thats what you have then, you go to top HIT FILE when drop box pops up HIT CONNECTION , make sure USB is chosen and then go to bottom and HIT CONNECT
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
