GameShark SP for Game Boy Advance Logo
Posted on Aug 22, 2009
I start up the gameshark and i put the codes i want on and i make sure the m code is on but when i start my game nothing happens it's just my regular leaf green game.
Anonymous
Level 1:
  • Contributor 34 Answers
  • Posted on Aug 22, 2009
Anonymous
Contributor
Level 1:
Answers
34
Questions
Helped
5972
Points
55
You have 2 click the names of the codes by goin right and activate it with a
Nothing happens except the number 8 shows up but nothing else happens with the gameshark 2.0
http://www.atariage.com/forums/topic/132541-some-help-with-my-new-gameshark-pro-3-3-for-n64/ Check this site... Check the pins in the cartridge and the game shark... Try with different games... Make sure its clean and making all connections. :) hope it helps.
How do I put in gameshark code on smugglers run 2
all you need is to have the gameshark disc and memory card other wise the disc is useless when u put the disc in make sure u have the memory card in too enter the codes save them to the game shark memory card and then reset the system and then put ur game in and u should have the cheats i hope i helped me and my two bros had the same problem
2helpful
2answers
GOD GARNED N64 GAMESHARK!
The original GameShark for the N64 only works on certain games. During the N64 era, game creators would often include code on the game itself that prevented the use of a GameShark. It is possible that you can find a newer version of the GameShark that would work with this so called "blocked" games, but it might be difficult.
I'm assuming that this is the GameShark Pro for the N64. If so, the button is used to find and create your own cheats, such as infinite life, infinite ammo, etc...
To use this feature, start the game, say a first person shooter, and load into a level and when you are ready to begin playing, press the button. The GameShark screen will show up and you can say "search for code" or "search for changes" something like that and the game shark will run a diagnostic that it shows on the screen. A number will appear noting the number of lines of code executed since the game loaded. When it is finished, press the button again and it will return you to the game exactly as you left it. If you are trying to get infinite ammo, simply shoot once and press the gameshark button again to search for codes again. When it is finished, the number it shows will be much smaller, since much less lines of code have executed since the last run. Press the gameshark button again to return to the game and continue the process until you have only a few, say 5 or less, or even just one code left on the gameshark diagnostic. This code will be the one that dictates the amount of ammo that you have. By altering this code with the gameshark, you can either start with an extremely high amount of ammo, or have infinite ammo entirely. The key to this strategy is to do as little as possible between code searches so that you can quickly narrow down on the code that you trying to alter. Hope this helps.
1helpful
2answers
I got a gameshark version 2.2 and i put in codes
Sounds like the game shark died, sorry for your loss
1helpful
I put the code i want and i press ok but when i start the game nothing happen
Your Gameshark mightve been used too much so now it glitches and stops.
2answers
Won't start game
Possibility that your gameshark is damaged.
try using a friend's, and if it works you need a new one.
Code on Gameshark doesn't work
It's because the cheats are designed for the GBA not the DS.
Though you have the right game, it just wont work.
3answers
Top GameShark Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a GameShark Video Game Console and Game Expert? Answer questions, earn points and help others
