Our sony trinitron 27" wega less than 5 yrs old..when powered up flickered off three times now stays on but the color is very red no matter if we reset or do a color adjust or unplug it from the cable box it still remains w/ a color too red!
  • 476 Answers
Sometimes picture tube tvs develop shorts between the internal electrodes usually cathodes to filaments causing the one or more of the guns inside the tube to go high in emission, when this happens the screen or picture you see will get excessively in this case red and some horizontal diagonal lines will also show causing the tv to shut down, another condition that may cause an excessive red screen may be a failure of one of the voltage source that feeds the color amp in this case the red ampl, this also may cause the retrace lines and tv shutdown.i hope this explanation helps you better understand what might be going on with your tv. In both cases technical analysis will be required and in some cases even the picture tube condition can be corrected with out having to resort to a picture tube replacement. i hope i answer the your inquiry to your liking and if so please let this site know by leaving some pos feedback.
Posted on Aug 22, 2009
6ya staff
SOURCE:
My 11 yrs old 25"
No,the tv main logic pcb board have dead components parts on it and also the tv video boad too.This tv must take to tvs shops and get estamate see it is worth the priced to be repair or compair the prices could be cheaper just replace another tv.
Aug 10, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony wega 36
power board...count flashes..if any. Call tech support
Jun 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
The picture has a green tint to it on all channels
The color signal consists of Red, Green and Blue. Those three colors, at various degrees, make all the other colors on your screen.
If you have a BRIGHT green screen it's best you don't operate your set.
If it's just tinted green then there is a problem on the CRT (Cathode Ray Tube) drive board. Do check your "tint" setting and see if someone misadjusted it. If that isn't it then you need to have your set on an electronics bench and get an estimate for repair.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
My sony 24in flatscreen has green color on right
dont power your tv near sound box or machines with magnet,
switch off tv, get a magnet and pass it all round your screen, it will clear with no time
Mar 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony Trinitron Wega KV-27FS100 picture on and off
i'd say your tv is unhappy.
unplug for 10 min..and see if that resets it.
May 31, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony tv kv-32fv300
you probably aren't checking this posting out anymore, but maybe someone else will see this and it can help them.
i was having the same problem, did a search and found this solution. worked like a charm!! go here:
http://www.floggingenglish.com/2008/07/22/diy-tv-repair-fixing-screen-flicker-on-a-sony-hd-wega/
Nov 24, 2007 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Sony wega
ok,just check the fuse if it is open,and when it is open,replace it with a new one.then check also the str,the regulator and the horizontal output transistor.
Oct 22, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony WEGA TV Red color wont display at all.
as other color are ok(blue&green)& no red colour.please check as follows. 1 check supply to red video transistor. 2 check for loose crt base. 3 check for loose connector 4 check components related to red video ckt.& cathode ckt. 5 check for red signal is coming to red video ckt. 6 check red cathoe voltage. 7 signal processor ic.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
WEGA 36" : Screen is low contrast and green
Sorry to say, it sounds like a bad picture tube, But could be also the capacitor that filters the screen voltage on the crt drivers. In all my years though, your complaint has been the picture tube. Good Luck.
Jan 02, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
