Question about Kenmore Sewing Machines
Have a kenmore sewing machine model 385.19233 that doesn't hold the material in place while sewing, the material slides around what do I need to do to correct this problem
Posted by kathy ziegelheafer on
Ruth summersides
    Genius:
  • Kenmore Master
  • 1,477 Answers
The presser foot needs to be tightened. Try that :-)
Posted on Aug 10, 2019
5 Related Answers
Anonymous
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
Anonymous
SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Posted on Sep 17, 2008
SOURCE: thread jamming, wont feed material, sewing in one place
Try moving the stitch length dial to 4 or 5 - check the manual. You may have it in the position for very close together sewing. I had to do a lot of trying with my 4795 to get it to work right. I found that very thin thread, polyester kind, broke at the needle after a couple of stitches. I switched to coats & clarks thread and a Singer ball point needle and it works fine. Be sure your needle is inserted with the flat top toward the back of the machine. Good luck!
Posted on May 27, 2009
WonderTech
WonderTech
  • 268 Answers
SOURCE: my kenmore sewing machine model 385.18221 is not
Here are several solutions to try.
- Re-thread your machine. It may be threaded incorrectly (backwards).
- Raise your feed dogs if your machine has this feature.
- When you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
- Reinsert your needle and make sure it goes all the way into the holder and that it’s positioned correctly – usually with the flat side away from the bobbin, but consult your machine’s manual to be sure.
- Change your needle, it may be blunt, bent, or otherwise damaged.
- Your fabric may require a different needle. Generally, heavier fabrics require larger needles and thinner fabrics, smaller needles. You may also need a larger needle if you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for woven (or a universal needle for either). Make sure your needle is appropriate for the type of thread you’re using.
- Adjust the pressure of your pressure foot. It may be too light for your fabric.
- Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both. And use a good quality, brand name thread.
- Adjust your thread tension, It may be too tight or too loose.
- Change your needle plate. Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important Note: After changing your needle plate, check to make sure your needle aligns perfectly with the smaller hole before starting to sew. A misaligned needle could hit the plate and break, which could be dangerous. And make sure to change your needle plate back for zigzag and other wide stitches.
I hope these solutions help you.
Posted on Sep 24, 2009
bilypunkerto
SOURCE: Manual for older kenmore sewing machine
Manual Here: http://www.managemylife.com/mmh/lis_pdf/OWNM/1006108L.pdf
Posted on Dec 23, 2010
What could be causing my Kenmore Sewing Machine to feel like its binding up to the point it won't move at all ?
most of these problems can be traced to cotton and fluff jamming the shafts around the bobbin area
you could try removing any jammed threads and fluff or take it to a sewing machine service center ( any one if not under warranty) as all know what to look for when a machine has your problem
remember quotes before work done
Mar 24, 2016 | Kenmore Sewing Machines
The tention is not holding the material in place slips around when im sewing .
Do you guide the material with your hands while sewing?
Jul 07, 2015 | Sewing Machines
I only want to know if the wheel must be loosened to wind the bobbin and if so with direction, to the front or backwards and press and turn or pull and turn.thanks
Which make and model sewing machine do you have?
None of my sewing machines need the wheel to be loosened for bobbin winding. The Singer Touch & Sew bobbins are filled in place. Use the handwheel to get the needle into the highest position (just turn the wheel). Wrap the top thread around the screw that holds the presser foot; open the slide plate part way and press the bobbin wind button. Hold the top thread and then begin winding by stepping on the foot pedal.. The thread should break after a few winds.
The Kenmore and the Husqvarna Vikings both get wound at the top. Place bobbin on winding pin. With the needle up and metal presser foot in place thread the top thread up to the bobbin (through the guides) and up through the hole in the bobbin. Slide the bobbin winding switch over towards the bobbin. Hold the thread tightly and begin winding (step on the foot control). After a few winds are on the bobbin, cut the thread that you were holding flush with the top of the bobbin. Continue winding the bobbin. (The newest Viking in the group has a computer screen; on that one, do not press OK until done winding the bobbin.)
However, if the handwheel is not turning and the needle is down, first find out why it isn't turning properly. This could indicate a tangle of thread somewhere in the system. (The older Husqvarna sewing machine in my home has a non-functional handwheel. The machine will still sew but you have to use the needle up/down switch that forces the needle to stop in the up position before you run out of bobbin.)
Please add a comment with the specifics of your sewing machine and I'll be glad to add additional information.
I hope this helps.
Feb 28, 2012 | Sewing Machines
I have cleaned and oiled my sewing machine according to book instructions. Before and after, it doesn't want to pull the material. Seems to want to sew in one spot. Can you help me know what to do?
check the feed dogs in the needle plate area to see if there up or down
look in the book and find where the lever is to change the position of the feed dogs. when there up the fabric will move, but when there down it stays in one place
Sep 10, 2011 | Kenmore Sewing Machines
30 stitch kenmore....model # 385 1884180 serial # 72004581 having problems with the thread bunching up on back side of material. not sure if my settings are right. lost manual for my...
It really depends on the type of material you are sewing. But most machines are set at around 4 from the factory. remember right to tighten, left to loosen.
Mar 11, 2011 | Kenmore Sewing Machines
How to stitch stretchy material on my Kenmore model 15202 sewing machine
Normally I would use a Q (blue needle) and some gift tissue paper. Hold both threads until you get going. I am not sure if just a ball point needle will do the same thing as the Q, which is a Sears product, or not. But it sure don't hurt to try it on a scrap piece of material and get the Q if you need it.
Jan 03, 2011 | Kenmore Sewing Machines
How to put thread on a bobbin of a Kenmore Sewing machine
I could not find a guide for this model.
If there is a knob in the center of the handwheel, it needs to be loosened.
Take the thread from the spool around the first guide and then to toward the bobbin winder.
Run the end of the thread through an opening in the side of the bobbin spool.
Hold onto about 5" of the thread and place the bobbin spool onto the bobbin pin and move the pin to the right or the winding wheel to the left (depends on how your machine is designed).
Holding onto the thread end, press the power pedal.
When you cannot hold onto the thread any longer, stop the machine and cut off the thread end and then continue to wind the bobbin.
Disengage the bobbin winder (move the pin or the wheel back into place) and tighten the knob in the center of the handwheel before sewing.
Mar 24, 2010 | Kenmore 12912
Thread jams in bobbin area
well i have done the same thing , all u need to do is if you see the screws that hold the bobbin area you un screwq thoes and get you a pair of scisors and cut around the knoted mess and all you do is work with it until it is all out and you dont realy want to pull on it to much you know just work it around so it gets lose so that you can cut it out thin you put it back together and try it out.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
When attempting to sew rather thin material the main presser foot has not enough downward pressure to keep the material from sliding around. This is on a Singer 111W. Works fine on leather etc. I thought...
This machine was not designed to sew THIN material. It is an upholstery machine and it will never sew thin fabric very well. You can try a smaller needle(size 16 or less) and shorter stitches. There is also an adjustment to raise and lower the walking foot located on the backside of the machine. It can be recognized by the wing nut holding it in place and that it slides up and down when it is loose.
sewman7
Jul 14, 2008 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
54 people viewed this question
Top Kenmore Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
tsalagi152
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
