I have an older D126 electric jenn aire drop in range, with interchangable parts. The burner side ( on the right) will not heat up intermittenly, but if I plug in the grill element on that side it will heat up.
Anyone have this happen. What was the problem ?
Also I need some parts, where is the best place to look.
SOURCE: knob not working and some burners not heating
The switch under that knob is bad. It's called an infinite switch. As far as the elements go, first thing to check is for proper voltage (220) to the cooktop. Let me know what you find.
SOURCE: Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
SOURCE: Both burners turn on when only one is needed
I just had the same problem- when I replaced the whole cartridge.
I repalced the infinite switch- do the one that gets the hottest- or do both.
It is easy to do- just write down the wiring diagram - make sure all power is off- cost of new switch was about $37.00
This solved the problem- however make sure to check the sizng on the new switch shaft as my old knob would not fit properly on the shaft of the new switch.
good luck
SOURCE: constant heat not produced on Jenn Air Schott Ceran stove top
It's a piece of ****, replace it the first chance you get.
