Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
Posted on Aug 21, 2009
Need belt for stackable frigidaire washer and dryer. Model is FEX831CS The washer jerked and threw a breaker. Now the dryer won't work and the washer lets water run in and the inside starts jerking hard
Anonymous
Level 1:
  • Contributor 38 Answers
  • Posted on Oct 03, 2009
Anonymous
Contributor
Level 1:
Answers
38
Questions
0
Helped
14786
Points
57
If you think that the washing machine belt is the cause of your troubles you can find it in the very bottom of the machine (behind the front panel)
Would need more info on the dryer problem, (Is it running with no heat or not running at all)
the washer drive belt is the only easy fix on this model.
Good Luck
Quentin
Just bough a used frigidaire stackable unit model FEX831CS and washer makes extremely loud noise on spin cycle. and dryer takes over 2 hours to dry a regular load of clothes. Please help
Hello uucyc1 - From what you have described it sounds like you either have a problem with the washer tub bearing, belt, motor or trunnion (steel bar that secures the inner basket to the transmission shaft). As far as the dryer, long dry times typically are a result of poor air flow. Make sure that the dryer exhaust vent is completely clear and that the unit is not overloaded. I would suggest contacting an experiencing service technician to determine the precise cause to both units.
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
I have a frigidaire stackable washer/dryer model number FEX831CS0 an the washer works but the dryer is seem not to be getting any power
Hello cbrhonda125 - Try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch. This is something that a professional would need to properly diagnose.
3helpful
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Can you buy a frigidaire stackable washer separately?
Have you had a qualified service man look at your machine? I would think that the burned rubber smell would direct you to examine the belt (found in the very bottom after removal of front cover).
If it is the belt it is a very easy fix on this machine. The not draining part wouldn't be related to the belt the pump that does the draining is driven by its own electric motor and is easily visible when the front cover is off. Its located on the bottom left side. If a sock or other small item manages to get over the side of the basket it always ends up jamming the pump.
You would have to take the pump apart to retrieve the item and restore pump function
Good Luck
Quentin
STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Belt installation whirlpool stackable
thats funny cause they dont have belts
most have motor couplings that will break and it wont spin
if it still agitates its gotta a motor coupling
Water won't work but dryer does
Mine did the same thing and it ended up being an overloaded older breaker in the electric box. It would allow the dryer to work, but the washer was too much for it to operate. Had the breaker replaced with a new one and it works fine. Hope this helps!
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
