Question about Dacor MCS130 Millennia Electric Single Oven
Im getting this message u60 cooling fan can some one tell me the meaning? Thanks
Posted by tconte1 on
Megan Webb
    Habit-Forming:
    New Friend:
  • 63 Answers
FixYourBoard.com will test and remanufacture the relay oven control board in this model. Each rebuild comes with a two year warranty.
Reach out to us at 512-355-1108 or [email protected]
im getting this message u60 cooling fan can - fixyourboard 101559 repair-undefined-undefined-0_8.jpg
Posted on Mar 24, 2020
Charles T Nevin
  • 4,070 Answers
There is a small fan you should be able to hear blowing when the oven has been hot for a while. The fan keep the electronic controls cooler so they won't be damaged by the heat.
Posted on Aug 22, 2009
Do i really need the cooling fan to work if i have bypassed the u60 code on Dacor oven
It obviously is requesting you to replace the fan and or the relay. If it comes with the oven it is definitely needed.. Bypassing anything could cause a fire and you would lose your home. I wouldn't bypass it. Please have it repaired correctly by an authorized repairman.
May 10, 2021 • Dacor Ovens
1helpful
F43 error on Frigidaire Wall Ovn?
The code F43 means - The cooling fan speed, as read by the tachometer input of the EOC-display board, is abnormally too slow. when the cooker is on can you feel the fan is on through the upper vent? If not then the fan is the problem if you can then the fan sensor is the problem!
Fan staying on
hello
Yes, this is normal. The fan stays on for a period of time to help cool the oven.
But if it stay too long then it means that there has been a problem on the wiring programming connected to the fan
thank you and thanks for using fixya.
2answers
Error message F64 appears when lower oven is turned on.
Hello,Note that lower oven cooling fan air switch not detected and that means you have to replace air switch,replace cooling fan,check connections,check P6 on PCB control display.
Thanks
1helpful
U60 Cooling Fan message on Decor MOV130
First, try to clear the code. To do this you must push and hold # and 'cancel' at the same time until the screen asks for an ID code. Then type in (using the key pad) S1234 (you get S by pressing 7 five times) Then simply press 'clear all' and the code should disappear.
Add a comment
    • 530gonzo
    • 51 seconds ago
    If that doesnt work then pull the oven from the wall by removing the door and unscrewing the stainless steel trim. Pull the oven straight out and attatch the pull handles to pull it completely out. Next, place the oven on a secure stand (such as a milk crate). Then turn off the breaker to all electricity in your kitchen and confirm the power is off. Then, using a 'Torx' brand bit, take off the sheetmetal cover on top of the oven. Download a service manual to your oven and check power to the fan as described in the manual. You can find service manuals on the web (do not use owners manuals) Next, check power at the Hall effect sensor as described in the manual. You just need a volt-ohm meter to do these tests. The manual describes it well. If these tests confirm the fan is not defective, you need a relay board. Dacor part #101559. I got one for $165 last week from Dacor. 99% of the time this is the problem and the boards are even back-ordered. Dont be critical of Dacor, the ovens work well. My advice is just to buy the extended warranty when you get one. Like any high performance machine, they run well if cared for by experts.
Mar 21, 2009 • Ovens
17helpful
2answers
Display reads U60 Cooling Fan - oven won't heat
I got Dacor to give me the number sequence -- - push "cancel" and "#" at same time - when screen asks for "service ID" enter "S1234" (get "S" by pushing "7" 5 times) - screen will list "U60 Cooling Fan" as number 1, so select "1" - select "clear all", this should clear the error - hit "cancel" to get out of that screen
Hope this works for you! Best suggestion I have is DON'T BUY DACOR!! We also own their 30" dishwasher, which has been a nightmare experience as well.
7helpful
3answers
The code is telling you that the oven has sensed a fault in the coling fan circuit of the upper oven. Dacor has had a few problems with the cooling fans in these new ovens since theyve been out, so most likely you will have a bad fan motor. If that is the case, be prepared to have the repair person have to pull the oven out of the wall to get to it and change it. If its a realy board problem (less likely) than that can be changed from the front. Call up Dacor and find an authorized servicer in your area since it will still be under warranty. Good Luck!
Dacor MCS130 Millennia Electric Single Oven Logo
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Paul Bade
Are you a Dacor Oven Expert? Answer questions, earn points and help others
