Question about Toys
Serial number 164010756 mf70 mficb This a Massy Ferguson backhoe frontloader
Posted by jason Riley on
5 Related Answers
  • 102366 Answers
SOURCE: I'm looking for a manual on a John Deere 2010
http://www.deere.com/servlet/com.deere.u90785.productcatalog.view.servlets.PublicationsSearchServlet
Posted on May 19, 2011
silawrence
Silas Lawrence
  • 906 Answers
SOURCE: My serial number for massey ferguson 35, is. SJ70494CD. Canyou tell me the tractors history
Sorry but I need more information, like what history
Posted on Jan 06, 2015
  • 18455 Answers
SOURCE: i have a case 580L backhoe serial number JJG0220588. what year was it made
Case is proprietary in everything they do. The model that you are talking about started in 1998. However the vin or serial number that you gave is not showing anything.
Posted on Jan 30, 2015
lpfaff1
L Pfaff
  • 11573 Answers
SOURCE: where is the serial number located on a john deere 510d backhoe..so i can find out the year of the backhoe
Diane, JD 510D VIN# Location: On older models plate is attached on outside of frame behind either left or right front wheel. On newer models VIN plate is attached just above left (Highway) side cylinder arm. Same location as Caterpillar. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://cppsocal.org/wp-content/uploads/2014/04/Heavy_Equipment_Catalog_Vol_5.pdf
https://www.oswca.org/uploads/combatting-heavy-equipment-theft-2015.pdf
Thread where is Serial number for 1977 John Deere 510 hoe
Serial number plate location for john deere 510d backhoe Google Search
Posted on Jun 21, 2016
solver2010
  • 923 Answers
SOURCE: cockshutt backhoe serial number 190-280-507 model number 255-72050 data
https://www.google.com/#q=Cockshutt+backhoe+model+255-72050
Posted on May 11, 2017
Massy ferguson MF34A Diesel leaking out from the screw plug on the boyttom of the diesel filter
replace the plug seal or copper washer
make sure that the fuel is not leaking from around the top seal of the filter and running down to that plug
Jun 08, 2017 | Cars & Trucks
Not necessary coming from the screw plug but may be from the filter seal or even from the fuel line entering the filter housing. The screw plug is the lowest point where the droplets are formed.
I have a 1085 when lift gets warm it will rase up but if you put weight on it wont lift
Massy Ferguson hydraulic pump is worn out. You might could drain the hydraulic oil out and fill with 80-90 sae gear lube that will work fine in that tractor.
Jan 02, 2017 | Cars & Trucks
Where is the serial number located on a john deere 510d backhoe..so i can find out the year of the backhoe
Jun 20, 2016 | John Deere Garden
Lookup serial numbers
Hi, here's a link to these specs. It looks like however that you did also find this info. Perhaps you'd comment if this was helpful. Thanks and good luck!
Just in case:
TractorData.com Massey Ferguson 362 tractor information
http://www.tractordata.com/farm-tractors/000/7/8/784-massey-ferguson-362.html
Aug 30, 2014 | Garden
Where would i find the chassis number on a massey ferguson 3115
Climb up into the tractor's seat. Look below the lower left-hand side and lower right-hand side of the steering wheel panel for the serial number. Certain older Ferguson tractors have the serial number stamped to a plate that is mounted to one of these areas of the steering wheel panel.
Serial Number Plate:
http://old20tractorparts.com/mf-165-tinwork-parts/1356-massey-ferguson-165-serial-number-plate.html
Inspect the left- and right-hand sides of the tractor's main frame. Certain older Ferguson tractors have the serial number stamped to a plate on the outside of one of these areas of the main frame.
Inspect the top of the transmission housing for the serial number. Certain older Ferguson tractors have the serial number stamped to a plate that is mounted to the top of the transmission housing.
Jan 27, 2014 | Aprilia Pegaso 650 i.e Motorcycles
Need to change hydro fluid, what sould I use
is it a Massy?
Do not use eng oil!!!
Kubota UDT, Case IH hy-tran ultra oils will work on most.
Apr 10, 2009 | Puzzle Massey Ferguson Tractor
Toys Logo
144 people viewed this question
Top Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
