Question about Power Computers & Internet
No lights in thepanel. No power - Power Computers & Internet
Posted by Conrado Venal on
  • Larry Ng
    Larry Ng Jul 06, 2019
    Hi Conrado Venal, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    what PC, you posted to computer repair, please stated a PC by name and model full.
Toshiba G3 remote panel dos not light up or have any control, is there a fuse for the control power to the thepanel
There might be a partial or no current contact, or something gone wrong right inside of the panel, a slick. Immediate solution is for you to take out the battery from the battery panel, and replace it or put it back again. Press shift + F8 + the power button at the same time. That will work the miracle and the problem solved.
Aug 19, 2015 | Toshiba Televison & Video
When I turn power on my acer aspire netbook the screen is black. The only light that lights up is the battery light. Do you know what is the problem and how can I fix it?
Have you tried turning it on using your adapter? If there is still no power light, try removing the power jack in the laptop and the power cable in the adapter and re-insert it both then plug it then test it again. If there is still no power light, try bending slowly the power jack cable in the laptop while inserted and slowly bend and move until you reach the power adapter. Observe the power light while bending the cable. If the light turns on while bending, the wire/s on the cable might be cut where you bend and see the power light turning on. If there's still no power light, your power adapter or the laptops power supply might be defective.
Sep 25, 2011 | Acer Aspire One Netbook 8.9" Notebook
Which button is the scan button ?
from the bottom of thepanel, it is the third row up.
here is the link to user manual
http://support.lexmark.com/index?page=answers&startover=y&locale=en&userlocale=EN_US&question=x2670#1
Hope this helped
Please rate FIXYA
Apr 07, 2011 | Lexmark X2670 All-In-One Printer
My linksys wrt160n wireless router light is blinking
Welcome to FixYa
Indication of Router Lights:
  • Power light blinks. If LAN or WAN cable is plugged in, their respective lights will flash on activity.
  • Power light turns off for several seconds.
  • All lights, except power light, turn on and then off.
  • Power light blinks slowly, then faster, and WLAN light will turn on.
  • Once Power light and WLAN light are on solid, the router is fully rebooted.
A working router should show solid green power light. upgrade the firmware of the router.
If this Helped you-Rate me..Thanks for Using FixYa
Jun 30, 2010 | Linksys WRT160N Wireless Router
I have a ge dishwasher model GSD5211 purchased in may 2006. Water appears to be dripping from under the front ss panel to the bottom of thepanel. I cannot open it to check the source of the leak. Alo found...
You may want to inspect the seal around the door to make sure it's not worn out or has some foreign material stuck to it causing it to not make a watertight seal during operation. If you don't see any problems there, then you should pull the machine out from under the counter to see if the drain hose has been damaged or dislocated. Most dishwashers are fastened to the bottom side of the counter by two brackets. Open the door to the machine and look at the top where it meets the underside of the counter to see how it is fastened. It's usually just two screws. Once you've removed the screws you should be able to gently slide it out and take a look at the drain hose. You may also want to take note of the condition of the floor below the machine to see if there is any long term water damage that either needs to be fixed or will give you an idea of the location of the source of the problem.
Hope this helps!
Jun 25, 2010 | Dishwashers
3 red lights on
Step 1: Turn on the console, and check the light on your power supplyThe power supply light is located on the black box that is in the middle of your power cord.
Figure 2: The Xbox 360 Power Supply light uparrow.gifBack to the top Step 2: If power supply light is green, try this solution 3frlgreen.jpg
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutions 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support
(source: www.microsoft.com)Kind Regards
Mar 23, 2010 | Microsoft Xbox 360 Console
Tree lights in red
Figure 3: Three flashing lights on the Ring of Light with a green power supply light Solution: Submit a console repair requestYour console is in need of a repair. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: Step 3: If the power supply light is red, is orange when the console is powered on, or is not lit, try these solutionsuparrow.gifBack to the top 3frlpower.jpg
Figure 4: Three flashing lights on the Ring of Light with a red, orange, or unlit power supply light Solution 1: Unplug your console, plug it into a different outlet in a different room, and then turn it onThis will help determine whether the problem is with your power supply, your power outlet, or your console. Solution 2: Request a replacement power supplyIf the power supply light is still red, orange, or not lit, the problem is with your power supply. Contact Xbox Support to obtain a replacement power supply. Contact Xbox Support(source: www.microsoft.com)Regards
F1 error code
F1 in unit implies....Inlet Valve Fault
    How to Test the Water Inlet Valve
  1. Step 1 Turnoff the power to the dishwasher. Dishwashers are direct fed straightfrom a dedicated breaker in your electrical panel. Find the breakermarked "dishwasher" and turn it off. Return to the dishwasher and tryto run it to make sure that you've got the right breaker.
  2. Step 2 Lookat the bottom front of the dishwasher; here you will see a set ofscrews holding a panel in place. Remove the screws and pull away thepanels (there may be two of them depending on your make and model). Thewater inlet valve is usually located directly in the front, on theleft-hand side. It is usually blue in color.
  3. Step 3 Remove the two screws holding the water inlet valve bracket to the dishwasher's frame.
  4. Step 4 Withthe inlet valve hanging free, pull the slide-on connector off of itsterminals. Make a note of which wire goes to which terminal, so you canhook the new one up correctly.
  5. Step 5 Setyour multimeter to read ohms (the Greek symbol for Omega) and touch oneprobe to each of the water inlet valve's terminals. If the multimeterindicates a reading of "infinity," then the valve is faulty and needsto be replaced. If you get a resistance reading, then the valve isprobably good and your problem may be elsewhere.
  6. How to Replace the Water Inlet Valve
  7. Step 1 Withthe power already off and the leads disconnected from the inlet valve,the only thing you have left to do to remove it is to disconnect thevalve from the waterlines. Before you remove any of the lines, be sureyou turn the water feed OFF. The shut-off valve is usually locatedunderneath your kitchen sink.
  8. Step 2 Place a towel underneath the water inlet valve. This will help absorb any excess water left in the hoses when you disconnect them.
  9. Step 3 Usethe adjustable wrench to loosen the fitting on the water feed hose.Once it is loosened, you can unscrew it the rest of the way by hand.
  10. Step 4 Takeyour pliers and use them to squeeze open the compression ring on therubber hose. With the compression ring open, slide it backwards, awayfrom the inlet valve, so it is no longer over the valve's nipple.
  11. Step 5 Pull the rubber hose off of the valve's nipple. If it is holding tight, try twisting it to break the seal.
  12. Step 6 Oncethe bad water inlet valve is removed, take the replacement and slidethe rubber hose over its nipple. Use the pliers to open up thecompression clamp, slide it over the hose until it is over the nippleand release.
  13. Step 7 WrapTeflon tape around the threads on the inlet valve, and then screw thewater feeder hose fitting over the threaded section. Secure it by usingthe wrench. Be careful you don't overtighten or you could cause a leak.
  14. Step 8 Turnthe water back on to check for leaks. If no water droplets appear, thensecure the water inlet valve to the housing of the dishwasher with thetwo screws you removed earlier.
  15. Step 9 Slide the wire connector over the terminals on the valve and replace the front access panel covers.
  16. Step 10 Turnthe circuit breaker back on and run your dishwasher. You should hearthe valve opening up to release water into your dishwasher as the cyclebegins.
    regards
    iversh
    A very helpful rating is appreciated for responding to your
    query....
Aug 30, 2009 | Dacor Epicure IDW30 Built-in Dishwasher
Locked panel on my TV
open up the television and disconnect the power board connectors and the connectors to the audio digital board --- then reconnect them and re connect the power cord - this will reset the television as it came from the factory
Feb 27, 2009 | Samsung Televison & Video
Solid orange light on motherboard when power light is plugged in
the light on the motherboard indicates power to the board, so it's completely normal. that might be the same for the power button light.
Nov 15, 2008 | Computers & Internet
Computers & Internet Logo
Top Power Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
