Car Audio & Video Logo
Posted on Aug 21, 2009
Cant figure out what all the wires go to
Cant figure out what all the wires on the harness go to
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Aug 21, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
3370
Points
35
Most car stereos have wiring for power, ground, speakers and amps/accessories, if you do not have an amp or fewer speakers you will not use all the wires, look in your manual or look on line for a wiring diagram to see what all the wires go to. Your main wires will be main power (usually Red) Back up power (for memory usually orange or yellow) a ground wire (usually Black) and speaker wires.
I need a wiring diagram for a 82harley sportster
http://www.ebay.com/itm/HARLEY-DAVIDSON-SPORTSTER-MAIN-INTERCONNECT-WIRING-HARNESS-70482-07-/161682525353?hash=item25a5078ca9&vxp=mtr
why cant you buy one???,there are alot of them for sale,or by the headlight harness only,
HARLEY FL FX SPORTSTER HEADLIGHT CONNECTOR PLUG 3 post CHOPPER BUILD
I cant figure out how to hook up my new raido in my car can u help
The easiest way it to get a wiring adapter, any auto parts place or even walmart sells them in the automotive radio department. They plug into the factor harness connector, but you will still have to splice the adapter to the new radio harness, but the wires will be color coded the same at the new harness.
1helpful
Im installing a radio in my 03 chevy avalanche and i cant figure out y it wont work
if you put it in with the wire harness that plugs into the trucks harness you have to make sure the amp turn on wire is connected from the radio to the harness if the amp isnt on you get no sound, if you didnt buy the harness and cut into the trucks wires you could have a problem, check all radio and amp fuses also
2answers
3helpful
Wiring diagram
Here is a manual for a deh-p43.
It should have the same standard wiring.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
My yamaha ttr90 wiring
you should be able to repair the harness just solder the wires and heatshrink the connection
the new harness costs
see pic
WIRE HARNESS ASSY
(5HN8)299268-001 $6.85
2answers
The left headlight of my xc90 will not work
you have this car posted under binoculars, not cars.
Jun 18, 2008 • Optics
2answers
Need to hook up a 200 pioneer stereo with wire harness from 96 honda accord to the wiring on a 64 impala
you'll need a small 12 v lamp to figure out which one has the power terminals. after mapping that out you need to find a small battery and hook it up to a pair of wires to figure out to which speaker the wires go to.
note : new car radios don't use the chassis ground as common (negative).. the head unit has a negative and positive wire for EACH speaker.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
