Canon DR-2580C Path-Through Scanner Logo
Posted on Aug 21, 2009
Black at the bottom of scanned pages
I have a Canon dr-2580C - how can I get rid of the thick black line that shows up at the bottom of the page after it is scanned.
PJ Williamson
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Aug 21, 2009
PJ  Williamson
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
0
Helped
13038
Points
42
There should not be a thick black line at the bottom, but could be from several things, light coming in from somewhere is my first guess, toner is almost out or the ribbon is getting stuck on the inside at that point. You may have to call Cannon and ask them.
Canon DR-2580C scanner only scanning half the page. What could be the problem?
Select Auto for page size. The scanning software displays scanned image in many options, including 'fit'. Choose 'fit' so that you see complete image.
S. Mohan
2helpful
Scanner only scans top page although set on duplex setting.
Switch the little button on top of the scanner next to the 3 buttons. This switches between 1 page or multiple page.
A.Misset
Installing these devices in the Netherlands.
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
1helpful
Dr-2580C Grabs more than one page at a time!! Losing Info!
If the rollers are old, you need to change it, else clean with a damp cloth. Dont use solvents. Ensure the papers are not sticky, loosen them if required.
S. Mohan
I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
1helpful
Canon DR 2580C Scanning issue
In Captureperfect, select page size as 'Scanners Maximum'. Select automatic paper size, check the output now. If you select bigger paper size and smaller paper, you will see lack output, outside the paper area.
S. Mohan, Chennai, India
Canon Dr-2580C
Try and scan a white paper. If the output is black, then may be the LEDs are not glowing, likely the wire is loose. Actually it is not easily reacheable! Try duplex scanning to check if both scan modules are fine.
S. Mohan
1helpful
Streaks in image scanned by Canon DR-2580C Path-Through
The staples cannot reach the sensors. They could have scratched the glass above the sensors. Clean the glass with IsoPropyl alcohol. Try scanning a few images to find if the scratch marks are on the same place on all images. Once confirmed that the glass is scratched, you can change the glass. You need a technical expertise to change or call service staff.
Canon DR-2580C Scanner
You must have 'checked' the multipage option in the scanning software. Try scanning first page only and store as say temp1 and later all pages as temp2. If the file size is different you can deduce that the scanner has scanned all pages! To view multipage files, you need a proper software.
S. Mohan, Chennai
old marine
old marine
ZJ Limited
ZJ Limited
