Question about Russell Hobbs Microwave Ovens
Can i use a silicone dish inside a russell hobbs rhsc650 . I would like to cook a potato gratin ,and when cooked put it under a grill to brown for a few minutes .thanks
Posted by Martine... on
5 Related Answers
Anonymous
SOURCE: russell hobs microwave oven
I am a recently retired appliance engineer of 20 years, microwaves are not normally things worked on yourself, i would be reluctant to help normally but yes there is an internal fuse ( a special quick blow type )just inside where the wire enters the cabinet on a small circuit board, if a replacement is needed it must be exact match bought from an electronic shop, microwaves are dangerous they store powerful electric and can still shock after removing the plug, if the replacement fuse blows, there is a fault elsewhere, and i do not recommend further self repair, work with safety
Posted on Sep 09, 2007
Anonymous
SOURCE: USER MANUAL FOR RUSSELL HOBBS CJS28 MICROWAVE WITH CONVECTION
Their customer service # is 0845-658-9700, their business # is 0161-947-3000, and you can e-mail them [email protected] I could not find a manual on their website so I guess you will have to the above #'s wurstdude
Posted on Nov 07, 2008
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: F5 lights comes
It's a shorted humidity sensor.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Nov 21, 2008
Ottoniel
  • 202 Answers
SOURCE: Model jvm131h002 Stopped working. no power or
yes, at the back of the microwave there are 4 or 6 screws, take them out and then pull the cover follow the cable( the one you connect to the outlet) going to the inside of the microwave inside you will see the fuse change it with the same size, it is a slow burn fuse
Posted on Aug 05, 2009
John Morganti
  • 864 Answers
SOURCE: Dimension 4 microwave stuck on demo mode
Here are is the manual:
http://service.us.panasonic.com/OPERMANPDF/NNT888S.PDF
Page 13 tells how to shut off Demo mode. (Press FUNCTION-0-2.)
Posted on Aug 12, 2009
Testimonial: "Thanks very much, it was driving me crazy!!"
How to heat cooked potatoes for mashed potatoes
hi Judy.
Put in the large pot as you peel and slice so they don't turn brown. Be sure water covers the potatoes by 2 inches, on medium-high heat and bring to a boil. Reduce to medium-low heat, cook the potatoes for 20 minutes until the potatoes are soft and fork tender. Turn off the heat, and drain well in a colander.24 Nov 2015
Make Ahead Mashed Potatoes Reheated 5 Ways - Delicious Table
https://www.delicioustable.com/make-ahead-mashed-potatoes-reheated-5-ways/
if you want to know more go to this link.
How to heat cooked potatoes for mashed potatoes Google Search
Nov 23, 2017 | Microwave Ovens
I need instructions for 10in. microwave browner
Only place I've found is here: CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Mar 09, 2014 | CorningWare Microwave Ovens
Auto Cook not working
If autocook is not working and everything else it, there is an issue with the sensor in the oven that detects the steam, The emission of steam is what triggers that unit to shut off. If it wont cook on any settings then the issue is with the microwave generator not putting out enough power. This could be from a lot of things.
Dec 16, 2013 | Sharp R959SLMA 900 Watts Convection /...
My Russell Hobbs microwave seems to be stuck on some kind of timer and I've tried everything to cancel it but it's not having any of it. When it's not actually cooking it seems to be in some get ready mode...
Put a glass of cold water in it as see if it heats up? All microwaves have a timer so that after cooking the internal fan stays on to remove cooking smells and condensation from the chamber. It should however turn off after about 5 minutes as long as the door is closed. The plate should only rotate when a time is set and the cook button is pressed.
Oct 18, 2017 | Russell Hobbs Microwave Ovens
How to use the Tesco mtg06 microwave grill?do not have instruction manual
The oven may be used purely for microwaving or simply as a grill for cooking such things as toast. The radiant or quartz grill may be used in a variety of ways. You can use microwaves that have grill functions to roast foods, for baking purposes or for grilling food such as bacon or sausages on the racks. Some models also allow you to use both the oven and grill together, and you can produce fantastically presented meals by using the grill to brown off your dish after cooking. The grill will often have low, medium and high settings for you to choose from, letting you control how brown your food is. By using a microwave with a grill, you can prepare great meals or snacks in a fraction of the time that it would take if you used a conventional oven and grill. Microwaves are particularly convenient, as you don't have to keep checking on the food or stand over it as it cooks.
Jul 29, 2011 | Sanyo Microwave Ovens
I am looking to buy a sandwich maker like the 17936 and set it on timer for the morning so they are ready for when I wake up and go to work - does this russell hobbs model heat up and then stop heating...
Here are a few links to some information about the Russell Hobbs Model 17936 Sandwich Maker:
http://www.amazon.co.uk/Russell-Hobbs-17936-Sandwich-Maker/dp/B002MRS1NM
http://www.reevoo.com/p/russell-hobbs-2-sandwich-maker
http://www.sonicdirect.co.uk/catalogue--iID--5785--russell-hobbs-17936-2-slice-sandwich-toaster-in-brushed-stainless-steel.php
I don't think you will find a small sandwich maker with the type of automatic timer you are describing. Most full size digital ovens have that function, but very few smaller units like the 17936.
Also, would it not be a bit impractical to leave a sandwich with perishable toppings in the machine overnight in order for it to begin cooking in the morning? Any kind of meat product left out overnight unrefrigerated may become dangerously contaminated and spoil.
For all the time these machines take to heat up, you might as well just get up 5 minutes earlier in the morning and prepare your sandwich then.
Good luck though either way.
Jun 14, 2011 | Microwave Ovens
Put a potato in microwave it caught on fire dish broke no power to the microwave...did I kill it for good or is there a reset button on it...the microwave in build into my cabinets back of microwave is...
When cooking a potato in the microwave Without puncturing it with a fork... it definitively EXPLODS braking the CAROUSSEL PLATEAU and probably damaging some delicate electronics inside, (you have to pearce the potato with a fork to let steem out when cooking) if you are lucky it could be just a blown fuse inside, have it checked by a proffessional (there is normally no reset for a microwave oven exception maiby for the control panel)
Jan 14, 2011 | GE Microwave Ovens
Microwave Ovens Logo
143 people viewed this question
Top Russell Hobbs Microwave Ovens Experts
William Miller
William Miller
john h
Andrew Taylor
Andrew Taylor
Are you a Russell Hobbs Microwave Oven Expert? Answer questions, earn points and help others
