Question about Canon PowerShot A620 Digital Camera
Hi my canon A620 camera - I have purchased two 4gb memory cards and both say they are locked. Is this the camera, are the cards too big a memory. thanks for your help.
Anonymous
    Sergeant:
  • 151 Answers
Canon doesn't typically publish information regarding the top capacity for memory cards, especially since new cards come out all the time and they'd have to continually rewrite their manuals.
I would, however, suggest getting a couple of 2gb cards instead of a single 4gb card. Not only is there less of a question of compatibility with 2gb cards, but if you misplace one, you still have a backup. A 2gb card will hold several hundred shots at full resolution and the lowest compression, so you won't have to worry about running out of space.
Hope this helps!
Posted on Aug 21, 2009
Testimonial: " xxx such a sensible solution.... thank you "
Can I use 8GB SD cards in my Canon Powershot A620 camera? I thought I once read that it will only support up to 2GB SD cards.
The A620 uses MMC and SD cards. SD cards max out at 2GB in size. Larger cards are actually SDHC or SDXC cards and will not work in the A620.
Jan 11, 2011 | Canon PowerShot A620 Digital Camera
I purchased a 4GB memory card for use in my A95. I occasionally get a 'corrupted file' error message. Is it possible the card is too big for this model? The card was formatted.
Yes, 4GB card is too big for Canon A95 camera as its hardware does not support such big memory.
Put max 2GB or less memory card in this camera.
Thanks.
Aug 02, 2010 | Canon PowerShot A95 Digital Camera
When I inserted the new memory card (SanDisk Ultra II, 4GB) into my Canon PowerShot A620, it tells me "Memory Card Error". This is a brand new card. What do I do? It had been working just fine with a...
Some cameras cannot handle over 2GB memory cards. If it works fine with 2GB card - stick to that. If some other A620 you know operates with 4GB card, take yours to repairs.
Oct 24, 2009 | Canon PowerShot A620 Digital Camera
Canon powershot A620 - putting a a memory card and it says memory card locked - it's a new card and it's not locked - what should I do?
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Oct 24, 2009 | Canon Cameras
Camera will not accept any memory card over 2GB. Keeps saying "Memory Card Error"
Most new 4GB and larger cards are SDHC cards (look on the card). Although they look exactly the same as a standard SD card, they are not. Unfortunately, there is no way that these cards will work with your camera, as it was designed before the SDHC format came out. As you've dsicovered, 2GB and less are standard SD cards, and will work with your camera.
There were a few standard 4GB cards produced a few years ago, most notably by ADATA (I have one that I use in my A620). Unfortunately, these are rare now, and are somewhat expensive if found on eBay.
Oct 11, 2009 | Canon PowerShot A620 Digital Camera
Put new SanDisk 4GB card in Canon A620 and get Memory Card Error
The A620 came out in 2005, before the SDHC (high capacity) protocol had been introduced. The A580 came out in 2008 and is compatible with the SDHC protocol. The A620 is only compatible with the SD protocol, and maximum capacity under this protocol is 2MB.
Aug 27, 2009 | Canon PowerShot A620 Digital Camera
I put a brand new SanDisk SDHC 4 GB memory card in and it says "memory card error; card is locked".
I also own an A620, but unfortunately I also learned the hard way that SDHC cards are not compatible with this camera. The A620 was designed before the newer SDHC format came out, thus although they look exactly the same, your camera will never work with these cards. Your camera uses standard SD cards (2GB or less). There are some standard 4GB SD cards, but they are very rare these days, and costly.
Aug 06, 2009 | Canon PowerShot A620 Digital Camera
Memory card error
The memory card could be too big. Some camera's can only use a certain size memory card. You will have to check your manual to see what the specifications for your memory cards. Hope this helps.
Jul 16, 2009 | Canon PowerShot A620 Digital Camera
Canon PowerShot A620 Digital Camera Logo
82 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
