Hi if when you put the hazzard lights on all the indicators work then this suggests the problem is with the indicator switch, you may need to get it replaced, it could be that it has got corroded due to rain or damp getting in, if the hazzords are working ok then you know the fuse and bulbs are good so all thats left that could be wrong is the switch that works the indicators. this will need removing and replacing to solve your problem
hi, be careful here as it can make your back ache,
now there is a lever to the right of the seat, pull it up towards you and
turn your seat 90 anticlockwise, so the seats not facing the control panel, at right angles, you should now be able to lift the seat , take great care here if you have back problems in the past as some seats are quite heavy.
My Pride Colt XL8 keeped cutting out (7 flashes of LED, Speed pot error) , checked all the cable connections up tiller arm as recommended by Pride technical support, worked for about a week, then problem returned.
Eventually took to Pride dealer, with problem occasional occurring,they found it to be the lower tiller cable support bracket straining the cables connector intermittently and so removed the bracket, the problem then was solved !
