Well i could say you need a new chip but remotes only support there range so ig you have a 30 mhz radio it will only use 40-49 chips.So the best way would be to buy a new reciever on your helicopter.
Unfortunately you can't. You will need to change the receiver or the transmitter so they are both the same frequency range eg 40mhz or 27mhz. Then you will need to check the crystal is the same frequency for the Transmitter and receiver eg 40.25mhz. NB. you can't put a 27mhz crystal into a 40mhz set or vise versa it won't work.
SOURCE: We have 2 boats, both
The ONLY way is to use different Channel Crystals in the Transmitter and Receiver, if you can do this, you buy the crystals in Pairs, 1 Xmitt & 1 Rec.
Go to your local Hobby shop, where they sell these types of things and they will be able to supply you with the crystals, usually they simply plug in...
SOURCE: New 27 MHZ Helicopter Controller won't turn on
I have a 27Mhz helicoper (looks identical to the one on the picture). I tried to fly it for the first time, but I am having problems controlling it. The left radio control lever sends the helicopter upwards, but the right hand control doesn't seem to do anything and that should make it go backwards and forwards. Can anyone help me as well please?
SOURCE: we have two gyros S107G remote control
Had the exact same problem. Found the solution on an Amazon posting:
1. To enable this function make sure both remotes and both helicopters are off.
2. Set the first remote's channel switch to the leftmost position (it says A, B, and C, but the s107 only supports 2 channels). Turn the remote on.?
3. Turn the helicopter that you would like to bind to the remote on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the helicopter should respond to this remote.?
4. Next, to enable the second helicopter, set the second remote's channel switch to the rightmost position (it says A, B, and C, but the S107 only supports 2 channels). Turn the remote on.?
5. Turn the second helicopter on and set the helicopter down on a flat stable surface for about 5 seconds. Try the throttle and the second helicopter should respond to this remote.?
This worked for us.
Testimonial: "excellent help. thanks a ton. now we'll just hope for no mid-air collisions. appreciate it!"
SOURCE: Me and my dad have
Turn both helicopters and remotes off. Then switch the remote to another channel, either a,b, or c, turn on HELICOPTER FIRST, turn on REMOTE second. Move throttle up and down, helicopter should start responding.
