Question about Canon ZR500 Mini DV Digital Camcorder
FireWire for camcorder mini dv
I need to transfer videos from my camcorder to a PC.
I'm using these elements: http://www.fixya.com/uploads/images/03022D6.JPG
My camcorder is Canon zr 500 (using DV)
I Connect the right cable to firewire port, open the camera, My PC indicates the driver [IEEE 1394 BUS HOST CONTROLLERS] is properly installed, but Windows Movie Maker doesn't open up - I open WMM manually but cannot see the camcorder viedos.
Any help please ?
Thanks
Posted by bbbsot on
  • bbbsot Aug 21, 2009
    Thanks guys,
    I've changed the SAME cable to a new one and it work just fine.
    No need to answer.
    Thanks
    Cloesed
old marine
  • 2,381 Answers
Go to this link. Click on "Frequently Asked Questions" and then click on the appropriate link (#4). Basically, once the firewire cable is connected, make sure that the camcorder is in the playback mode, is turned on, and you see "DV IN" on the LCD. If all that is happening, your computer/software should be able to "see" the camcorder and download the video.
Posted on Aug 21, 2009
4helpful
I have a samsung VP-D70 camcorder and I want to transfer data to my laptop. The DV out on the camcorder is descibed as 4 pin the other end of the cable supplied is not usb (it has 723 on the connector).I...
This is a Firewire cable, also known as DV or IEEE 1394. Sony call it i.Link. It is not compatible with USB and you cannot get a lead to connect it to a USB port. There are converter/adapters that are supposed to allow Firewire to connect to USB but many forum posts say they do NOT work for video transfer. Unfortunately, most Mini-DV cameras will not transfer video by USB cable, even when they have a USB connection (it is usually only used for still pictures).
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. If you had a desktop PC, you could fit an add-on Firewire interface card to the expansion bus. This will come with a driver for the card.
I have a Samsung Mini-DV, and do transfers with it to the one computer I have that has a Firewire port. It is the only thing I use that computer for, and the reason I haven't thrown it out.
2helpful
How I can attach firewire cable to my pc ? Anyother way to transfer vedio from sony dsr hc21 ?
If you want to transfer video using a firewire you need a 1394 connection on your PC. The Sony DCR-HC21 will also allow you transfer video using a usb cable.
Transfer from pz card shot on HD to mini DV tape
you can transfer to DV tape only by using software like Edius 6 or a similar one.
First you download the p2 card on the hard drive and then you use this program to convert the video file to DV and use the camcorder as recorder connecting to pc via firewire .
1helpful
I want to transfer the video from camcorder to pc
to transfer video from your camcorder to your pc you will need a firewire cable (ieee 1394). only with this cable you will be able to transer video.
you will also need a firewire port on your pc.
if you don't have one then you can buy a firewire pci card.
see this for info and pictures
http://en.wikipedia.org/wiki/IEEE_1394_interface
I am not able to transfer video files from my Sony camcorder DCR-PC120E onto my PC or Laptop inspite of all efforts and connecting with correct DV CABLES . cAN YOU SUGGESR ME THE CORRECT PROCEDURE TO...
to transfer the video try using Windows Movie Maker that comes with windows XP.
How can I transfer the video from camera (Mini DV) to PC?
I cant seem to transfer videos from my camcorder to my pc, the media 4.0 does work properly and i'm not sure what i should be using to connect my camera to my pc
2answers
Can i transfer video from a canon mv830i to my pc
How do I transfer my mini dv video to my pc?
1helpful
Transferring video to a pc
If your pc has a firewire port, then you won't need a card.
Canon ZR500 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
