Passwords. Those ubiquitious alpha-numeric codes that protect us and
give us access to everything digital. Unfortunately, passwords can be
confusing because, though your computer likely won't forget a password,
you very well might. When this happens, you can be locked out from your
whole system, as in the case of the Windows XP Administrator Password.
This article will show you how to remove an Administrator password.
Instructions:
Insert your Windows XP CD into your CD drive and boot your
computer. If you receive the message "press any key to boot from CD,"
press any key.
Step 2
Press Enter to setup Windows. After accepting the license agreement, you wil be asked if you want start a Repair process.
Step 3
Press
R to begin the Repair process. Setup will now check your disks and then
start copying files, which can take several minutes. After this,
reboot. Let the computer boot normally (do not press a key to boot from
CD).
Step 4
Keep
your eye on the lower left hand side of the screen. When you see the
Installing Devices progress bar, press SHIFT + F10. This will open a
command line console.
Step 5
Type
NUSRMGR.CPL at the prompt and press Enter. This will give you access to
User Accounts. Remove or change your password. Write it down! After the
repair is finished, you will be able to log on with your new password.
Here I collect some popular solutions to help reset HP laptop password if your laptop installed Windows system such as Windows 7/Vista/XP.
Solution 1 Reset HP laptop password by another user account with administrator privilege.
Solution 2 Reset HP laptop password with Offline Windows Password & Registry Editor.
Solution 3 Reset HP password with professional password recovery tool.
If you do not have another administrator account on HP laptop or you have little experience in Windows or LUNIX operations, you can use Windows Password Rescuer to help reset HP password without lose date. This software was provided by DAOSSOFT corperation, it supports HP laptop password recovery in Windows 7/Vista/XP and HP computer installed Windows 7/Vista/XP/2008/2003/2000.
So you lost your Windows XP user password? You can try your best
to remember XP account password, such as: your name? a loved one's
birthday? something from your childhood? a pet's name?your home or
office address?
1. Enter a computer that can link to Internet. Download a Windows password recovery tool (I recommend Windows Password Recovery Tool 3.0 ) and install it on that computer. Note that: there is a ISO image file. Burn the file into a CD or a USB flash drive.
2. Eject the created CD/USB and insert it into the locked computer.
3. Reboot the locked computer (it's necessary for you to change your computer's Setup to make it boot from CD drive or USB drive) and then followed the process of instructions. Just a few steps, the old password was removed.
I suggest you try hard to remember your password! If you really can not reset your windows administrator password, I recommend Windows Password Seeker, passwordseeker.com I had removed Windows password with the tool successfully on my computer. Hope it helps! You simply do as follows: Step1, download Windows Password Seeker. Step2. Remove your Windows Password with the tool. If having some questions, you can read carefully at: http://www.passwordseeker.com/howtouse.html
As you know, if reinstall the computer will lead to lose data. In order to avoid data loss, you can remove the password with windows 7 password reset tool. I found a good one at http://www.reset-windows-password.com/reset-windows-7-password.html last week, then downloaded it and used it to remove the lost windows 7 password within only few minutes.
You can use a program likeWindows Password Recovery Tool to get the admin password. It is a live cd easy to use.
When you load it in graphical mode select the windows installition and then select the user you want to reset password.
(make sure you boot from cd/dvd or usb first)
