Sewing Machines Logo
Question about PfaFF Sewing Machines
Pfaff performance 5.2 I can not get it out of free -motion. I've read the book , pushed buttons and cannot get out of there.
Posted by Selby Horton on
5 Related Answers
Anonymous
  • 53 Answers
SOURCE: Pfaff Select 4.0 has looping on bottom of fabric, free motion qui
Make sure your are lowering the pressure foot first before you start sewing. With the free motion foot, you still have to lower the pressure foot, this allows tension to be put on the top thread and allows the foot to work properly (when the needle goes down so should the foot and when the needle comes up it should lift the foot up.)
Also make sure your tensions are in a middle setting and that you are threading the machine with the pressure foot up.
The way to insure you will not get your problem is with the foot up, you should be able to pull the thread easily right before the eye of the needle and when you put the foot down you should then feel a fair bit of tension on the top thread.
hope that helps :)
chris
Posted on Jun 06, 2010
SOURCE: My Pfaff 4.0 breaks needles
a sewing machine I work on last week, I put a new needle in the needle clamp & thought I had it correctly inserted,, but it wouldn't work,, so I went back & checked the needle again & found I had to unscrew the needle clamp screw even more than normal to insert the needle then it work perfectly.
some needles & thread don't work togeather--here's a tip
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
also clean under the needle plate where the feed dogs are for lint
& also in the bobbin area for lint & loose threads
Posted on Nov 18, 2010
SOURCE: pfaff tiptronic will not free motion
contact pfaff customer service about a manual
Posted on Feb 28, 2012
99rannellis
R.A. Ellis
  • 12731 Answers
SOURCE: I purchased the free motion foot. This Pfaff is on a power stand will zigzag and straight stitch. Pfaff 11
What is your question?
Posted on Apr 05, 2017
What settings do I put my old Pfaff 1214 on to do free motion quilting?
black lever on front (position right-normal sewing, position up-reverse, position left darning(free motion).Use the proper foot (jumping).Regards, JB
I have a quilt expression 2044 and need a free motion quilt foot, 93-036 963-91/00. I went to a shop that sells pfaff and they said it is no longer available.
Although the dealer may no longer sell the "original" foot for your machine, there are usually "used" presser feet available from sites like eBay. OR, you can purchase non-Pfaff presser feet that will work just as well on your machine. Just be sure to verify that the presser foot is compatible with your model (the shank style will determine whether it will work on your machine).
Pfaff Free Motion Open Toe Quilting Foot
Free Motion Darning Foot Pfaff 820243096
Pfaff Presser Feet
Pfaff 113 want to free motion quilt the foot will not allow me to se. I even took the screw for adjusting preasure all the way out and it still has too much preassure
Sounds like perhaps you have the incorrect foot. Did you perhaps purchase a quilting foot (used for piecing)? A free motion foot is actually shorter in height so it will not contact the feed dogs or needle plate. It is this added space that allows the fabric to be moved freely under the foot. Also, be sure to drop the feed dogs.
Open Toe Free Motion Spring Foot
Open Toe Free Motion Foot
Pfaff 113 free motion foot Google Search
If the presser foot is still too long, perhaps the shank is not correct for your machine. Sorry, am unable to locate information re your particular model.
Sewing Machine Feet
Will the Fab u motion with stitch regulator work with a Pfaff 2046?
You should probably verify with either the vendor selling the stitch regulator unit or your Pfaff dealer. It would be best to get a guarantee before purchasing.
http://www.allbrands.com/products/21646-free-motion-assistant-7x9-frame-with-quilters-crui#tab_product_description
http://www.quiltingboard.com/main-f1/free-motion-assistant-t98619.html
http://www.allbrands.com/products/21647-free-motion-assistant-7x9-hoop-frame-qcc-w-o-stitc#tab_product_description
1helpful
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
2answers
How to set 2140 for free motion sewing
Which model are you using? Creative 4.5?, On the newer machines it drops automatically once the embroidery attachment is hooked up. On older Creatives v2.x there is a slide lever in front of the presser foot on the front.
1helpful
Pfaff tiptronic will not free motion
4helpful
4answers
I am looking for pfaff hobbylock 786 serger manual do you know where I can get one?
ISBN 0-8019-8192-1(hc)? or ISBN 0-8019-8191-3(pb) by Naomi Baker & Tammy Young - "Know Your Pfaff Hobbylock" covers Pfaff Hobbylock: 797, 786, 784, 783 - Great book. This book is more helpful since it has detailed info pics in color- 182 pgs, @$3.00. Lists parts, projects, etc. The 786 manual has errors, 35 pgs. not detailed as the book above. Good luck! Fairlyart
Top PfaFF Sewing Machines Experts
Marvin
Marvin
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
