I have fixed nearly everything on this washer and now have a new problem. A few weeks after replacing my control board (ouch), the washer now finishes the cycle with water in the bottom six inches on a random basis.
Here is what I am sure of:
1. The program selection doesn't cause the problem. It is completely random.
2. When I hit drain/spin it does so. But if I don't take the clothes out right away, the tub fills again.
3. The clothes do not spin as dry as they used to.
Here is what I think the solution is, but the blogs I have read do not describe my random drainage problem, so I am not sure.
A. I should clean out the filter behind the bottom filter.
B. I should check the hoses for obstructions.
C. I should check a valve that may be failing that prevents either the water supply or the drain hose from filling the tub to about 4 inches of water. Sometimes 6 or more inches, but usually 4.
Any suggestions?
The water pumped goes right back into the machine. It may be because the washer is siphoning the water from the laundry tub with a slow drain and back. Your solutions are advised but try this also:
