Pretty much the same issue as the one above. :( I just bought the house 10 days ago and the dishwasher was already here. Used it about 5 times and it worked fine...now only certain buttons light up when pushed, Start/Cancel does not work at all...and then the lights go off and machine never starts. Any help or suggestions would be appreciated before I start looking for a repairman.
Thanks!
In such cases it is always the control panel(touch panel) that needs to be replaced.it is very simple 2 chg and u could save lot of money.to chge cntrl panel ,open the door and remove all the screws around the white plastic part of door.then pull apart the inner part from outside part.the cntrol panel is held to outer panel with 4 screws.b4 that remove 2 screws holding the control board to panel.do not forget 2 unplug the unit from power b4 doing anything.
