HP Pavilion dv9000z Notebook Logo
Posted on Aug 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sound when i try to click on my hp laptops sound button it dose not work a second time, how do i fix it
  • Anonymous May 11, 2010
    be more specific ???
Anonymous
Level 2:
  • Expert 91 Answers
  • Posted on Aug 21, 2009
Anonymous
Expert
Level 2:
Answers
91
Questions
5
Helped
51505
Points
224
I suggest you to install HP Quicklaunch buttons drivers to resolve this issue....... To download here is HP link to download and install http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-57820-1&lc=en&dlc=en&cc=uk〈=en&os=228&product=3224058
No Audio Device
Check your BIOS settings. I had the same problem with a 8440P. It has been a real Odyssee to find the solution, but I turned out the integrated audio device was disabled in the BIOS.
1helpful
My HP laptop (pavilion dv9700) will not start up. It was working fine then suddenly shut off while the cord was plugged in. The blue ring still lights up where you plug in the power chord, but nothing else...
Try the following:
  1. Unplug the power cord from the laptop.
  2. Remove the battery.
  3. Press and hold the power button for 10 seconds.
  4. Re-insert the battery.
  5. Plug in the power cord.
  6. Try turning on the computer.
My problem is only sound driver of my hp pavilion dv5215us Entartainment Notebook Pc. IT HAS NO SOUND
Method 1: Use the Windows XP Sound Troubleshooter How to fix it automatically
To fix this problem automatically, click the Fix It button, and then click the Run Now button. Then, follow the steps in the FixIt wizard.
a.button { background: url("/library/images/support/KBGraphics/PUBLIC/cn/FixItButton.jpg") no-repeat scroll 0pt 0pt transparent; width: 139px; height: 56px; display: block; cursor: pointer; }a.button:hover { background-position: right bottom; } Fix this problem
Microsoft Automated Troubleshooting Services: Diagnose and fix sound playback issues
Note This wizard may be in English only. However, the automatic fix works for all language versions of Windows.
The audio on my hp laptop only works when the headphones are plugged in, and the mute button stays orange and wont change to blue, but when i press the mute button the icon in the bottom right hand corner...
why not load the HP drivers of sound first.
that would proved its software or hardware so very easy
no>?
ever heard of HP>?>
NO OS stated, so how can anyone help lacking that KEY FACT.
windows what>?
you left out the dash, lacking the dash , HP cant find it.
G72-259WM
then go here. and use the right model and bingo.
support, all in 5 seconds work, posted here 1000s of times.
https://support.hp.com/us-en/product/HP-G72-200-Notebook-PC-series/4150030/model/4221434
then click software
then pick windows
then what what windows (today is how to fish day)
i guess and pick w7-32
and see what, the top of the list is driver -audio
load that driver, now.
if that fails, the hardware is bad, get it fixed.
10helpful
3answers
Brand new Hp probook 6540b blank black screen after battery dying fan also works over time any ideas to fix?
I have had this. Unplug the laptop, take the battery out and hold the power button for 30 seconds.
HP told me this was caused my "excessive charge on the mainboard"
The above process drains the charge
1helpful
HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Turning on &sterio problems
Hi, my problem was that I had trouble turning my laptop on. It had been getting worse over the last couple of years. It was suggested that the power button should be replaced. While searching the HP site on how to do this, I ran across a solution that said to take out the battery, unhook anything else that might be connected to the laptop, and then press the power button for around 10 seconds to drain all remaining power out. Then put battery back in and try to turn on. It worked! My laptop now turns on and off just fine! Hope this can help someone else....Linda P
1helpful
Mute Button (touchpad)
This could be a simple driver glitch. Try uninstalling the audio drivers from the device manager, then reboot. The machine will find he sound card and reinstall the drivers automatically. Then go to HP's support site and check for any updated sound drivers or patches. If it's a glitch this will fix it. Keep in mind that it could also be a hardware problem with the mute switch, so if the driver procedure doesn't work, you might consider having it serviced.
6helpful
7answers
HP Pavilion Entertainment PC
I was having a similar issue. My volume button worked fine muting and unmuting the volume, the light just stayed red either way.
I went into Device Manager, then expanded the Sound, Video and Game Controller options, I rolled back the driver and it was an instant fix for me :)
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
