Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
My Delonghi Magnifica (manual not digital) won't start the grinder, could this be the circuit board?
Posted by adrianpancal on
Anonymous
    New Friend:
Delonghi Magnifica comes up with waste tray full light when there is nothing in the tray. It doesn't make coffee, the grinder is rotating and appears to be clear. Could there be a blockage below the grinder, if so how do I access it.
Posted on Aug 30, 2010
  • colin ross
    colin ross Aug 25, 2015
    Hi I have delonghi magnifica110.s the light you mentioned if a stable light you need to put beans in the machine the grinder will run but knows there is no coffee in hopper and will not dispence coffee,now if the light is flashing this means the bin is full and need to empty,if this is the case when you slide bin back into place make sure you can hear a click this is the micro switch which is located inside the machine open up the front door remove bin in the bottom left corner there is a hole that is were the micro switch is just to be sure put a piece of cardboard in there to enable contact you will hear a click if not the switch could have been pushed in meaning the lip on your bin is not contacting switch remove bottom of cover underneath your machine to access it
All lights blinking red simutaneously
grinder is very fine, turn the knob inside the coffee to a large chislo.Ako not fix it, there are probably some trash between the blades of the grinder.
Nov 26, 2013 | DeLonghi Magnifica 3300 Espresso Machine
Poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The grinder on my DeLonghi seems to be stuck. It makes only a noise but not s bean is ground and one can hear it is not turning. Any solutions? Thank you
Likely a foreign object is blocking up the grinder. Remove all beans and run at coarsest grind to try to clear it, chase it through with more beans if necessary. If this does not clear it then the top burr of the grinder assembly can be removed after disassembling the machine. Mark the grinder coarseness cogs before moving them to assist reassembly. Moderately difficult procedure.
Aug 11, 2011 | DeLonghi Magnifica 3300 Espresso Machine
DeLonghi Esclusivo Magnifica grinder cogs have stopped spinning while the hub turns, thus no grinding is done! Help
u need it all set back up///needs grinder tanken out . if lugs are broken u need to put new grinder in....
Jan 25, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica 3500.. error message says "grind too fine, adjust grinder, insert water spout, press ok" message never goes away. I called the Customer service.. she said try again.. to...
Try removing the beans from the hopper and use a vacuum to CLEAR/REMOVE any grounds and then adjust the grinder 4 clicks clockwise. If this works Re-adjust grinder to where you get nice crema.
You can try using all ready ground coffee by following the instructions in your manual (if you don't have a manual let me know) to test it.
Jan 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
The machine makes a very loud noise when grinding the coffee beans. * Magnifica Espresson Machine *
Even a properly operating super automatic DeLonghi espresso machine makes enough coffee grinder noise to scare your pets and wake you next door neighbors. It's LOUD, no doubt about it. Only if your grinder makes more noise than that do you have a problem.
Jun 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
Jan 13, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
2,134 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
