Motorola Mobility H350 Wireless Headset Logo
Posted on Aug 20, 2009
H350 does not work as audio device
The problem is a driver . even though it's paired. the microsoft driver isn't good
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Apr 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
4345
Points
14
I was able to use my Motorola H350 Bluetooth Headset on Windows 7 by installing the drivers found in this link: http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Good luck! It took me about a week to find the solution.
1helpful
2answers
Need Windows 7 64bit drivers for Bluetiger BH-M20 Bluetooth headset
I have scoured the web on the issue of BT headset failure on Windows 7. Here\'s a summary of what I did and if this doesn\'t work, plug in a wired headset or get a #$)( Mac.
I\'m on the latest Windows 7 (as of April 2013). It discovers my Blue Tiger (bluetigerusa.com, eBay purchased new) Delux BT headset (dual ear w/ mic - designed for truckers), and even with WIndows BT driver up to date http://www.broadcom.com/support/bluetooth/update.php, Bluetooth Support Service restarted (Start > services), device successully added with device pairing mode (Windows Add BT device and holding device button down for 15 seconds until blue and red LEDs flash alternately - pink on some phone devices), and Windows sound device (Start > sound) Playback & Recording tabs right-clicked to enable "Show disabled devices," the headset still fails to show as a playback or recording device.
Simply put, all versions of Windows after XP have sucked. They change the UI to please Microsoft but with no apparent value to the user and though the help text is noticably better than former versions, the product itself is not. If Microsoft is going to try to reinvent the Mac, I\'m just gonna go get a Mac. Microsoft should stick to Ms Office apps, which they do well. Even Apple went Unix, having to admit that their own OS was absolute rubbish. Is Microsoft preparing to die? There\'s simply no innovation there. Perhaps they should hire some ex-Disney Imagineers?
Can't pair my Lg arena km900 with H350 bluetooth
To pair both the devices FIRST bluetooth should be ON in both device. Enable your "show to all" in your connectivity settings. Both device enter the same passcode.
2helpful
2answers
I cannot connect my h350 headset to my phone how doi I do this
on your phone open your bluthooth section and(1) turn on bluetooth. then in the bluetooth options, (2)have your phone ready to search / find devices. (3)on the h350 press and hold the power button for about 5 seconds until the blue light comes on and stays on. it is now in paring mode. (4)tell ur phone to search for devices. your phone should find it. (5)then select the h350 on your phones found devices list. they will now pair. its possible a password will be requested, i believe the factory default password for the h350 is 1234. your phone password may be the same as your phone unlock code or your voicemail code.
time is limited you may have to do this a couple of times before they actually pair together.
I cannot get the motorola H350 device to work
You have to pair it with your cell phone or other device.
Here is the userguide
Want to remove Motoraola H350 Bluetooth from MOTORAZRV3T phone
Hi
Try going into paired devices or active devices and delete from there
2helpful
H350
for more clear instructions go here
http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Before you can use your headset, you must
pair (link) it with your phone.
Step A - PUT HEADSET IN PAIRING MODE
Note: To turn off headset, see "Turning On and Off" on the
reverse side of this guide.
PAIR
Your Phone
Select (Menu) > Settings > Connection >
Bluetooth Link > Handsfree > Look for Devices.
The phone lists all Bluetooth devices it finds.
Select Motorola H300.
Press OK or Yes to pair (link) the handsfree
device.
Enter the passkey 0000 and press OK.
Note: Passkey cannot be changed
from 0000.
Step B - SET THE PHONE TO LOOK FOR
YOUR HEADSET
When your headset is successfully paired
How do I put the Blue Tooth device into pairing mode?
first switch on ur mobiles bluetooth connection......... then switch on ur moto H350..... then it automatically ask to pair with ur mobile jst accept it........ and then enter the pass code 0000.........kkkk... then it get paired... kk..........
No sound on headset even though it has been appropriately paired to my Treo
I too faced exactly the same problem..My phone was the Nokia N70...I too thought initially this was a problem with the headset...But when I had my phone re-started, then the headset started working fine...So I think this problem is related to the phone...Try this out...All the best!
115helpful
12answers
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
