Pioneer DEH-2100 CD Player Logo
Anonymous Posted on Aug 20, 2009
Setting the clock on my deh-1800 pioneer
Lost the manual, can't set the clock.
Frank Fulton
Level 3:
President:
  • Pioneer Master 1,114 Answers
  • Posted on Aug 21, 2009
Frank Fulton
Pioneer Master
Level 3:
President:
Answers
1114
Questions
Helped
502952
Points
3541
Http://www.pioneerusa.com/pio/pe/vgn/images/portal/cit_11221/49545CRD3133A_200012301341830.pdf
Herre's your manual. Page 15 & 16 show time set. Hope this helps.
Testimonial: "I've been looking for this. Thanks !!!!"
How do I set the time on my pioneer DH3700 MP car radio ?
I can't find a DH-3700MP on any Pioneer Electronics site. I did find a DEH-3700MP, https://www.pioneer-car.eu/dk/en/products/deh-3700mp/support .However, this model doesn't have a clock.
There is also the DEH-P3700MP, https://www.crutchfield.com/S-pFBTooZ0OGM/p_130DEHP370/Pioneer-DEH-P3700MP.html . Setting the clock is shown on page 34 of the manual, https://pdf.crutchfieldonline.com/ImageBank/v20070116102800/Manuals/130/130DEHP370.PDF . To set the clock, press Function repeatedly until the clock appears in the display. Use the left/right arrows to select either the hours or the minutes. Use the up/down arrows to reach the current time.
I hope this helps.
9helpful
Set clock on car radio.
Here is a link to the owner's manual for the stereo which will tell you how to set the time:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130DEH1800.PDF
5helpful
Pioneer DEH-1800 how to set the clock
Hold SOURCE until the unit turns off.
Hold AUDIO until the clock appears Use the LEFT or RIGHT adjust
Can't find how to set clock
Try page 10 of this link to your Pioneer DEH-1800 Owners Manual.
http://akamaipix.crutchfield.com/Manuals/130/130DEH1800.PDF
You will need to copy and paste the above link to your browser.
How to set clock
Not sure if you have tried this yet or not but try turning the radio off and then holding down one of the buttons for a couple secs to set the time. I have to set mine with the radio off and thought maybe you hadn't tried that...
How do i set clock on pioneer deh 1800
here is the link to your manuals:
http://www.pioneer.co.uk/uk/support/manuals/DEH-1800R/index.html
no instruction in there for setting clock!
usually is the same here are the usual instructions:
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select Clock.
Clock appears in the display.
2 Push MULTI-CONTROL left or right to
select the segment of the clock display you
wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the clock display:
Hour—Minute
As you select segments of the clock display
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
set the clock.
Pushing MULTI-CONTROL up will increase
the selected hour or minute. Pushing
MULTI-CONTROL down will decrease the selected
hour or minute.
Notes
! You can match the clock to a time signal by
pressing MULTI-CONTROL.
— If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes
10:00.)
— If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
! Even when the sources are off, the clock display
appears on the display. Pressing CLOCK
when the sources and feature demo are off,
turns the clock display on or off.
Turning the clock display
on or off
You can turn the clock display on or off.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Note
appears on the display. Pressing CLOCK when
Note: on some models you can only set the clock with the clock on display and power off on radio.
Cheers!
11helpful
2answers
Setting clock radio
Press and hold down the "clock" button. You should see your time start flashing. Normally you set the time with the volume or channel control. Check which control lets the selector jump from "hou" to "minute and set the minutes. To exit setting menu, depress "clock" button again
3helpful
Setting the clock
Hold source button till radio turns off and clock turns on. Hold Function till clock blinks. Press arrow keys to select direction of time. Then press Source again. All done
1helpful
2answers
I NEED TO KNOW HOW SET THE CLOCK ON A DEH-1500 PIONEER
Hi Elimo
Two pics as the manual had the paragraph separated. This is for DEH 2500 only. Let me know if you want the 1500 as well.
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
