Whirlpool MH1150XM Convection/Microwave Oven Logo
Posted on Aug 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Odd buzzing after timer stopped, food was still being heated
My Whirlpool microwave of the same model as above has been well used. We bought it in fall of 2003. Today I heated something for 10 seconds, but after the time was up I noticed a loud buzzing noise and it was coming from the microwave. It was still cooking the food but the turntable stopped and the time I set had expired. I pushed stop and nothing happened, I opened and shut the door a few times but this didn't stop the buzzing either. The only thing that stopped it was leaving the door open. After a few minutes it stopped altogether but I have no idea why this happened in the first place.
Anonymous
Level 3:
  • Whirlpool Master 43,501 Answers
  • Posted on Sep 30, 2010
Anonymous
Whirlpool Master
Level 3:
Answers
43501
Questions
0
Helped
10845008
Points
101584
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
r6uw
My galanza microwave, air fryer, oven will not heat while using microwave and makes a terrible racket?
here are some items to check for troubled microwave
Bad Magnetron Symptoms What are some bad magnetron symptoms to watch out for?
The following is a brief list of some of the most common signs that your magnetron is about to give out:
Heating: Either the microwave is not heating up at all, or the heating performance has degraded noticeably.
Burning Smell: A burning smell (non-food related), may be an indication that elements of your magnetron are overheating. In this case, switch off your microwave immediately, and arrange for a repair or replacement.
Unusual Noises: All microwaves make a bit of a hum, but if it's become much louder - or sounds like unusual vibrations - your magnetron may need to be replaced. Watch out for a clicking sound as well - that's a tell-tale sign of a magnetron that's about to fail.
Is It Worth Replacing The Magnetron In A Microwave?
It really depends on the cost and age of your microwave. If it's somewhere between five and seven years old, you're in the right period of time for a replacement anyway.
There's little point spending good money on repairing or replacing a magnetron if the rest of the appliance is likely to give up the ghost soon anyway!
Symptoms of a Bad Microwave Diode? (Answered!)
A microwave diode is one of the most important components in the appliance. Without it, it's impossible to generate the heat required to heat foods and drinks placed in the oven cavity. Unfortunately, the component can go bad, so it's important to understand the symptoms of a bad microwave diode.
Generally, the symptoms of a bad microwave diode include sparking, buzzing and humming, and the appliance failing to heat. Running a continuity test helps to determine whether the diode has a problem. Getting a new diode for replacement is the solution if the current one fail the continuity test.
3 Symptoms of a Bad Microwave Diode The following table shows the summary of the symptoms of a bad microwave diode as well as what you can do to fix the problem:
Symptoms Solutions 1. Microwave buzzing and humming Inspect the diode, test it for electrical continuity, and replace it if it fails the continuity test. 2. Microwave not heating Start by inspecting the capacitor and magnetron because they may also be responsible for making the microwave fail to heat. 3. Microwave is sparking Locate the diode, inspect it, and test it for continuity. Replace it if there's no continuity. There aren't too many symptoms of a bad microwave diode. The most common ones include sparks & burning smells, the microwave not heating, and the microwave making humming & buzzing.
1. Microwave Starts to Have Heating Failures
Apart from a failed main control board, a faulty fuse cavity, a blown line or thermal fuse, and a faulty door switch, the high-voltage diode could also be the possible reason why the Whirlpool, Kenmore, GE, or KitchenAid microwave is not heating.
Your microwave failing to heat is a perfect sign of a faulty diode, which means you should get a new one for replacement.
2. The Microwave Starts to Pop Sparks
Sparks in your Kenmore, LG, Samsung, or Whirlpool microwave could be a sign that the high-voltage diode is defective.
Also, a burning smell from your microwave can indicate that the diode is bad. A burned-out diode can break into two, wear out, or short.
Immediately locate the diode in the cabinet next to the magnetron and replace it.
3. Microwave Starts to Make Noise
Your microwave could be buzzing and humming because the high-voltage diode is defective.
Apart from the diode, other components that can make your microwave make noise are the plate & drive motor, cooling fan, and magnetron.
Keep in mind that you can't repair a bad diode. You can only replace it with a new one.
Safety Warning
While repairing a microwave, the chances of falling into electrocution by the high-voltage capacitor even after unplugging the power cord from the socket are very high.
So you need to be very careful when doing the diode test.
To begin with, the high-voltage diode is located close to the high-voltage capacitor. In fact, one of its ends is attached to the high-voltage capacitor.
And as you know, a microwave capacitor carries high power voltages, which can be quite lethal. It is therefore important to start by discharging the capacitor before getting to the high-voltage diode.
Although the capacitor can store charge for a long time, touching both its negative and positive terminals with a metal screwdriver blade will drain all the charge in seconds.
Testing the Microwave Diode
Before you even attempt to replace the diode on your GE, Whirlpool, or KitchenAid microwave, do a functionality test to confirm your suspicion.
You can visibly confirm the diode is burned-out when you see physical damages.
In case there are physical damages, use a multimeter to test if the diode still has a continuous electrical path.
To test the diode for continuity:
Touch the positive and negative terminals of the high-voltage diode with the multimeter probes.
If the diode test negative for continuity on both of its sides, the diode has failed and will need a new one for replacement.
Microwave maiking loud noises
Tip #3: Weird Noises
. A high-pitched noise while the microwave is in use means there's a good chance the magnetron tube or diode is failing. If the exhaust fan or magnetron tube are the culprits, you will need to call a local appliance repair service.
DIODE HIGH VOLTAGE You might have an issue with the high-voltage diode if your microwave is generating an odd or loud whirring sound. This element, together with the magnetron and the capacitor, is a part of the high-voltage circuit. The cabinet needs to be taken out in order to get to the diode.
BUZZING AND HUMMING Most buzzing or humming noises are frequently caused by the fan motor, vent fan, magnetron, or any combination of these. This noise from routine operations gradually gets louder over time.
As the microwave oven warms up, the oscillation happens, and the fan helps keep the mechanical parts from overheating. You might need repairs if the volume of your microwave suddenly increases.
Try running the magnetron at a lower power setting while putting food inside to see whether the magnetron is the cause of your problem. This will cause the magnetron to switch on and off to maintain the proper temperature. If the magnetron is the issue, there should be less noise.
CLICKING NOISES Even though your microwave might not have a revolving plate, some models spin food using a glass turntable or plate. This component aids in ensuring even heating throughout your meal. However, occasionally clicking noises may result from this action.
If you constantly hear clicking, see if your glass plate, roller ring, or track needs to be cleaned. These are simple to clean with soap and water, but you might have neglected to do so. The location of the plate is what determines the other option, so be sure it is still on course.
POPPING As you prepare food or after spilling food, you might describe the sound of your microwave as popping, crackling, or snapping. However, these tones frequently come from dishes with significant water or fat content, particularly sauces.
POWERFUL SOUNDS When it comes to microwaves or other appliances, these noises continue to be the most alarming. You should replace your microwave if the device starts to make an electric-sounding noise called arcing.
If you notice that while using your microwave, the electricity flashes in addition to making a sound.
Stop using your microwave if this occurs and you notice a hole in the back o WHY DOES MY MICROWAVE MAKE A VIBRATING NOISE
There can be various reasons behind a microwave making vibrating noises. Some are given below.
POWER MOTOR Your microwave's drive motor may be malfunctioning if the turntable is making an odd noise. The majority of microwaves with glass trays turn the tray with a motor-driven coupler or a roller guide.
Access must be made through the bottom of the oven because the motor is normally found below the floor. Normally, a holding screw holds the motor in place, and two wires are connected to it as well. The motor must be replaced if it is creating a grinding sound.
its because it is now dangerous.
A loud humming or buzzing sound could result from a damaged magnetron
PUSH COUPLER If your microwave is making an odd noise, the drive coupler for the turning tray can be the cause. The majority of microwaves with spherical glass trays revolve around the tray on a roller guide using a motor-driven coupler.
A drive coupler with an offset center roller is sometimes used in models that employ a rectangular tray to move the tray guide from side to side. Remove the tray and roller guide from the oven for either style and then check the coupler. Before you can pull the coupler off the motor on some models, you might first need to remove the motor from the bottom.
ROLLER GUIDE If the turning tray in your microwave makes an odd noise while rotating, there might be an issue with the roller guide underneath the tray. A motor-driven coupler is sometimes used in microwave ovens with spherical glass trays to turn the roller guide.
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
My microwave oven buzzes when plugged in
Normal it buzz when you left yo food inside even its fin7shing warming or wateva youre doing, but if its just buzz you can disconect it if you want or take it to the technician
Ge spacemaker microwave jvm1640cj03 stopped heating. interior always clean. light, timer etc working.
If it stops heating and the other parts of the oven still work, the problem is with the magnetron circuit. If it makes a loud buzzing noise when you try to heat the food, then the magnetron has shorted out. The replacement cost for the magnetron is almost as much as a new oven, so it does not make sense to have it fixed. Sorry.
9helpful
3answers
Whirlpool MH1150XMB-0 runs but does not heat food
If the housing of the unit isn't too difficult to remove (normally 3-5 Phillips screws around the rear edge), with the unit unplugged of course, check for a user replaceable fuse inside. The magnetron is separately fused and fuses can fail due to metal fatigue. It will be high amperage; 10-20 amperes and many hardware stores will have them. BTW, there is no residual radiation from a magnetron that isn't operating.
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
2helpful
My GE spacemaker microwave doesn't heat up foods. There is a slight bit of heat generated but not much. All timers, lights, etc. work normal. It is a GE model jvm1440. It is about 3 years old. The problem...
IT COULD BE A NUMBER OF THINGS RANGING FROM DIODES TO CAPACITORS TO YOUR MAGNATRON OR THERMOSTAST OR TRANSFORMERS. IT'S DIFFICULT TO DIAGNOSE WITHOUT SEEING THIS MICROWAVE. YOU MAY BE BETTER OFF GETTING YOURSELF A DIFFERENT ONE.
1helpful
Kenmore 721.80524500 makes a buzzing, grinding noise
Your problem is due to the "magnetron" arcing to the wave guide within the microwave. Picture someone arc-welding stuff together inside the microwave casing, that's essentially what's happening. It is a fire hazard and you should stop using the microwave immediately. As far as I know, there isn't a recall on that particular model (though there was on another similar Kenmore/Whirlpool model) so if it's out of warranty, you're out of luck.
Microwave does not heat/cook
hi
power spikes are very damaging to a microwaves internal parts, it sounds like your transformer and/or magnetron are blown. if the unit is out of warranty I would recommend calling a repairman or getting a new microwave (the transformer & magnetron are expensive and dangerous to work on) also get a small single plug surge protector for the new one.
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
