SOURCE: how do I set the clock?
go to the web site (jvc) and they will have a manual that you can download.
SOURCE: JVC KW-AVX710 not save. after switch off the car
If your unit is not maintaining it's memory, it may be associated with the lack of a constant 12 volt power source. Test the units yellow wire, it should rest at 12 volts with the key in all positions; off, acc, on/run, start. This yellow wire should be connected to the vehicle's battery wire. Also, test the red wire. This wire should be connected to a switched 12 volt power source. It should read 12 volts with the key in accessory and on/run only. If you used a vehicle specific wiring harness to complete the installation, the wires may be switched in the harness. It's not a common issue but, I have seen it happen.
SOURCE: KW-AVX810 Car DVD Player: how to change the region code of JVC KW AVX-820...
Please get the code here :
www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__8ifr4
SOURCE: how to set clock jvc kw-xc770 car stero
1 Press SEL for more than 2 seconds.
One of the PSM items appears on the display.
2 If "PSM CLOCK H" does not appear, press fast forward and up or fast backward and down repeatedly until it appears.
3 Turn the control dial to adjust the hour.
4 Press fast forward and up or fast backward and down until "PSM CLOCK M" appears on the display.
5 Turn the control dial to adjust the minute.
6 Press SEL again to finish the setting.
http://www.jvc.ca/manuals/KW-XC770.pdf
