Question about Pioneer PureVision Pro-800HD 43 in. Plasma HDTV
Pioneer PRO800HD loud pop and flash of light AXY 1059-c
I am trying to fix this myself since it seems pretty expensive to buy these PSU boards. This one is an AXY1059 C which is used in a variety of Pioneer and Hitachi Plasma TVs.
I attempted to replace the shorted parts and now had a new explosion, I must have missed something.
Here is what I did first time around. I replaced Q127 (FET K2651), it was shorted all ways. I had to replace R217 (.47 ohm near Q127) and R133 (.1 ohm) both were blown apart (the loud pop/flash).
After replacing these, I thought I was fixed, but When I turned it on, it made an even bigger explosion, not quite what I wanted to see.
Now Q129 (SMT transistor AY6) blew off of the PCB and R217 is blown apart again. But what is worse, is an SMT resistor (R218 connecting to Q129) blew off the PCB and I have no idea what its value is.
I also need the value of C164 as it was missing on my TV, I put a 220uf cap in for now as a best guess for filtering. No idea why it was gone.
Does anyone know the values of these parts, or what all to replace to get it working again? I am willing to shotgun all suspect parts now that I have seen the way this thing explodes if I miss something (I suspect Q129 was bad and I didn't see it).
Posted by Jim Skilskyj on
  • Jim Skilskyj Sep 15, 2009
    OK I found out that R218 is an SMT 223 (22K) resistor and C164 is actually a 10V 1200uf cap. I am still working on this supply. Now I have two of these supplies to fix.
adoublee
    New Friend:
I'm working the same problem. Q127 shorted, R217 & R 133 open. Also have solder blown off one end of R222 and R351 (both sm 200 ohm). Looks like small, short trace evaporated on top layer between D145 and via directly below it. Q129 is open all ways (but not exploded).
This one has C164 installed as 1200 uf, 10V.
Any success getting your going again?
Posted on Oct 26, 2009
Anonymous
    New Friend:
Wow !, I have just done the same thing. I replaced all the same stuff you guys did and I was still missing some low voltages I tried to scope some patterns. The main problem here is no schematics show the power supply board I have a hitachi (pioneer pdu50wx2a) rebadge. The good news is the updated board is an axx1064 it`s an update to the board we are working on. around 330.00 I would get it from pioneer at least you know you will be getting an updated board.
Posted on Mar 17, 2010
  • Anonymous Feb 07, 2011
    This is a little late (understatement), but the power supply for these third gen Pioneers, the AXX1064, is also sold as the HITACHI TS04071. Which can be bought for about half the price ($175 vs 334). They are the exact same part they just carry a different SKU/part number. Hitachi used to sell re-badged Pioneers as their own. They usually even come in the packaging. They can be bought from encompassparts.com or partstore.com.
REPLACING THE POWER SUPPLY PIONEER PRO-1540HD
It is not an easy to do work, as you assume. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 16, 2014 | Pioneer Elite PRO-1540HD 60 in. Plasma...
My pd503mxe power supply got disrupted and is not available in the market. so please suggest me from where i can get this supply
Hi, I have a main power supply board which I may sell as I have replaced mine and it has turned out to not be the faulty board, Kevin. Board number is axy 1059-H
Jan 17, 2011 | Pioneer PureVision PDP-503MXE 50 in....
I have a 2003 Pioneer SD 533HD5, that powers up and then shuts back off immediately. I have read other post with this same problem. It seems to be some sort of fuse issue. How can I fix it myself. ...
If it's failing to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core (no laminations as with a line-frequency part) transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
You may find one or more fuses on this board as well.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, the PSU may not be repairable but if you can find a part number on the board, you might be able to buy the power supply from the mfr. and install it yourself but it will likely have the same problem eventually unless they have altered the design or improved component quality.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the main power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
Dec 13, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer Elite. Loud popping sound and picture disappeared
Power supply board is dead.The board where the power a/c cord plug into it.Replace the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 30, 2010 | Pioneer Elite PRO-1140HD 50 in. Plasma...
I heard a loud "pop" and the sound and picture went out. When I try to turn it on, only the green light flashes, no sound or picture.
Power supply board is dead.Replaced this power supply board will fix this problems.Tries Shopjimmy.com,Ebay.com to to buy a refurbish power supply board for the replacement.
Mar 10, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
When switching on...clicks, but no pic and red light flashing... must reset by switching powerswitch off than on..this went on sporadically for 4yrs..now samething happend accompanied by a loud pop and now...
Hi Pepe.
Only when there is no power at all, no led on, and no sign of life whatsoever, that means that the problem is likely the internal power supply board.
If instead the TV stays in stand-by, with the LED light on and flashing, but does not respond to remote, or to the buttons on the chassis, then the TV is in protect (safe) mode because an internal fault had been detected. In this case the fault is not necessary the PSU. Parts must be tested to find out. The clicking sound is the protection circuit that keeps turning off the PSU to prevent further damage.
If the problem is the PSU, often it is possible to see at a glance that one of the big electrolytic capacitors in PSU board has blown.
General troubleshooting on this article: Why my TV does not start up and remains in... . I do not think it will help in your case.
If that does not work, contact the manufacturer at the number listed on the owners manual to get the TV repaired by a licensed technician.
Pioneer covers the PSU or other parts even out of warranty only when a determined factory defect concerning that model and year had been reported by a number of technicians.
To find the contact see:
USA:Pioneer Electronics
Contact us - Pioneer Europe
Pioneer Electronics Asiacenter
Contact Us - Pioneer UK
contact us - Welcome to the pioneer global media Website
Regards.
Feb 18, 2010 | Televison & Video
The power button is flashing red...
It ur power board,Tries buy it replaced it ur self it pretty easy.
Nov 18, 2009 | Philips 50PFP5332D 50 in. Plasma...
I have a SONY WEGA flat screen, last night while watching tv, there was a loud pop in the tv, now the LAMP light keeps flashing and there is a grinding sound coming from in the set. No Picture, no other...
The loud pop was a capacitor blowing.
The light is flashing because either power board or ballast board is faulty.
Using the TV in this conditions can cause further damage.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
You can find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
May 04, 2009 | Sony WEGA KDL-42XBR950 42 in. LCD HDTV
Loud pop and tv went off...
Here is a solution from the Pioneer web site:
http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas
Important: Updated Information Regarding Free Power Supply Replacement for Certain Pioneer Plasmas Pioneer is continuing to offer a free, in-home/office power supply replacement for certain of its second and third generation plasma models listed below for customers who experience a problem with the original power supply. If a model is not listed below, no power supply replacement is needed and no further action needs to be taken.
If you own or use a plasma listed below, please call our toll free hotline at 1-800-421-1404 to arrange a time to have your plasma's power supply upgraded at your residence or office at no charge.
Plasma Models (15 listed):
  • PDP-505HD
  • PDP-503PU
  • PDP-5030HD
  • PDP-5031HD
  • PDP-433PU
  • PDP-4300
  • PDP-4310
  • PDP-4330HD
  • PRO-800HD
  • PRO-800HDI
  • PRO-1000HD
  • PRO-1000HDI
  • PDP-433CMX
  • PDP-502MX
  • PDP-503CMX
The issue with the power supply in the plasmas listed above does not pose any health or safety risk. Pioneer has received reports that the power supply in the affected models may fail. In some cases, a loud popping sound can be heard when a power supply fails. After the power supply fails, the plasma is no longer operable.
Anyone with questions can call Pioneer's toll free hotline at 800-421-1404.
We apologize for any inconvenience.
Aug 09, 2008 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pioneer pro800hd plasma just made a loud pop and then went to black the power button(red led) is flashing. power supply??, flyback xformer??? any ideas. worth fixing??
The affected models of consumer plasmas are listed below. Anyone who owns or uses one of these models may contact Pioneer through its toll free hotline at 800-421-1404 to arrange for the free, in-home upgrade. If a consumer model is not listed below, no power supply replacement is needed and no further action needs to be taken. If consumers are not sure if their plasma is affected, they should call the toll free hotline for confirmation.
Consumer Plasma Models (13 listed): PDP-505HD PDP-4330HD PDP-503PU PDP-4300 PDP-5030HD PDP-4304 PDP-5031HD PDP-4310 PRO-1000HD PRO-800HD PRO-1000HDI PRO-800HDI PDP-433PU
Dec 30, 2007 | Pioneer PureVision Pro-800HD 43 in. Plasma...
Pioneer PureVision Pro-800HD 43 in. Plasma HDTV Logo
2,169 people viewed this question
Top Pioneer Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
