If I remove the water filter completely, can I still make ice and use the water dispenser?
Please advise,
***** Lawrence
Lawrence, you will need to get a filter plug that replaces the filter, if you don't want to use the fridge filter element, otherwise, you will not be able to get ice and water from the dispenser.
I tried to look up the part you need, but the model number you provided appears to be missing some alpha or digits. I would suggest you contact KitchenAid or the retailer where you purchased it from, and ask them to order you the plug. Sometimes these fridges are shipped with the bypass plug installed and the new filter gets put in at installation by the delivery people, etc. If yours already had the filter installed, you'll have to buy a filter cap/plug in order to still get ice and water from the fridge.
Here's a link to a possible plug for your fridge:
http://store.appliancezone.com/servlet/-strse-56329/appliances-parts-repairs-replacements/Detail
Here's another one you can look at, just scroll down and you'll see the plugs mid-way down the page.
http://www.easyapplianceparts.com/appliancepartlist.aspx?Brand=KitchenAid&Appliance=Refrigerator&ModelNum=&Type=Filter%2C+Lint+-+Air+-+Water+-+Grease&MinSize=U&MaxSize=U&Electrical=U&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
I hope you find this Very Helpful and best regards!
Posted on Aug 20, 2009
Water Filter Status Light (on some models)
The water filter status light will help you know when to change
your water filter. When the water filter status display changes from
"GOOD" to "ORDER," this tells you that it is almost time to
change the water filter cartridge. Replace the water filter cartridge
when the water filter status display changes to "REPLACE." If
water flow to your water dispenser or ice maker decreases
noticeably, change the filter sooner. The filter should be replaced
at least every 6 months depending on your water quality and
usage.
After changing the water filter, reset the status light by pressing
and holding the FILTER button for 3 seconds. The status light will
change from "REPLACE" to "GOOD" when the system is reset.
Changing the Water Filter
1. Press the eject button to release the filter from the base grille.
2. Pull the filter straight out.
3. Turn the cap counterclockwise to remove it from the filter.
IMPORTANT: Do not discard the cap. It is part of your
refrigerator. Keep the cap to use with the replacement filter.
4. Align the ridge on the cap with the arrow on the new filter and
turn the cap until it snaps into place.
NOTE: You can run the dispenser without a filter. Your water
will not be filtered. Simply insert the cap all of the way into the
base grille and rotate the cap until it is firmly in place.
5. Remove the covers from the O-rings. Be sure the O-rings are
still in place after the covers are removed.
6. Push the filter into the base grille. The eject button will pop
back out when the filter is fully engaged.
7. Flush the water system. See "Water and Ice Dispensers."
Water Filter Status Light:
The water filter status light will help you know when to change your water filter.
When the dispenser control panel's water filter status display changes to "ORDER," this tells
you that it is almost time to change the water filter cartridge.
Replace the water filter cartridge when the water filter status display changes to "REPLACE."
The filter should be replaced at least every 6 months depending on your water quality and usage.
NOTE: If water flow to your water dispenser or ice maker decreases noticeably, change the
filter sooner. After changing the water filter, reset the status light.
Details:
Pressing and holding RESET FILTER starts the 3 seconds countdown. Using the dispenser
cancels the countdown AND no dispensing is permitted. The number '3' blinks 3 times and the
'invalid' tone sounds 3 times and user has to release both the pad and the button and press
the button again to start it over
After 3 seconds, the BLUE WATER BARS in the Icon flash and an audible tone sounds 3
times. When the system is reset, the "ORDER" and "REPLACE" icons will disappear from the
display screen. See figure 16.
Note: Users can reset the filter status at any stage.
If you should need the complete and exact model number and manual with parts manual you will need to enter the Model Number here=> Manuals, Guides and Instructions Please rate this solution, Thanks, Sea Breeze
User manual click HERE
