How do you flush the panafax uf-8000 memory?
Your killing a fly with a sledge hammer. If you do a ALL JOB clear from test mode 6 instead of SHIPMENT SET... you wont loose all your one-touches or fax parameter settings.
Hi
Thanks for using FixYa. Press Function key/Menu key, then press 7. After this press monitor key slowly 4 times & then press * (asterisk key), now press 6 and scroll down to SHIPMENT SET, set 2. This will reset your Panasonic Fax to factory defaults.
Also see this link for User manual for your Panasonic UF-8000 Fax--
Panasonic UF-8000 Fax User & Instructions Manual
Please do rate the solution and revert for further assistance.
Thanks
Rylee
